Skip Headers
JD Edwards EnterpriseOne Application Pack for Oracle Enterprise Manager Cloud Control Implementation Guide
Release 9.1
Part Number E26776-02
Go to Documentation Home
Home
Go to Book List
Book List
Go to Table of Contents
Contents
Go to Master Index
Master Index
Go to Feedback page
Contact Us
Go to previous page
Previous
Go to next page
Next
PDF · Mobi · ePub
7 Deploy the JDE AppPack into the Management Agent
This chapter contains the following topics:
See Also:
7.1 Prerequisites to Deploying the JDE AppPack into the Management Agent
You can deploy the JDE AppPack to the Enterprise Manager Management Agent after you have:
7.2 Deploy the JDE AppPack into the Management Agent
You should follow the steps in this section to deploy the JDE AppPack into the Management Agent.
This image is described in surrounding text.
  1. In Oracle EMCC, navigate Setup > Extensibility > Plugins.
  2. With the undeployed plugin highlighted, right click and choose Deploy On > Management Agent...
  3. On Deploy Plug-in on Management Agent, General, in the Selected Management Agent section, click the Add button to add the JD Edwards EnterpriseOne target.
  4. On Search and Select: Targets - Oracle Enterprise Manager, highlight the target which is automatically found by Enterprise Manager and click the Select button.
  5. On Deploy Plug-in on Management Agent, General, verify the JD Edwards EnterpriseOne target machine is added and click the Next button.
    On Deploy Plug-in on Management Agent, Review, a warning is displayed indicating that the deployment of the plug-in on a managed host will restart the agent.
  6. Click the Deploy button.
  7. On Deploy Plug-in on Management Servers, Confirmation, click the Show Status button. This Confirmation screen indicates that the deployment is started on selected hosts.
    The EM interface shows the progress of the deployment.
    Once the status indicates the agent is being started, the deployment is complete, depending on how long the actual startup takes to complete and that the EMCC session will soon be available.
