Skip Navigation Links
Exit Print View
Oracle Integrated Lights Out Manager (ILOM) 3.1 Documentation Collection
search filter icon
search icon
Document Information
Using This Documentation
Related Documentation
Documentation Feedback
Product Downloads
Download Product Software and Firmware
Oracle ILOM 3.1 Firmware Version Numbering Scheme
Support and Accessibility
Quick Start
Oracle ILOM 3.1 – Quick Start
Factory Default Settings
Mandatory Setup Tasks
Optional Setup Tasks
Daily Management Tasks
Routine Maintenance Tasks
Initial Setup FAQs
Configuration and Maintenance
Setting Up a Management Connection to Oracle ILOM and Logging In
Establishing a Management Connection to Oracle ILOM
Logging In to Oracle ILOM Server SP or CMM
Configuring Oracle ILOM for Maximum Security
Setting Up and Maintaining User Accounts
Managing User Credentials
Configuring Local User Accounts
Configuring Active Directory
Configuring LDAP/SSL
Configuring LDAP
Configuring RADIUS
Modifying Default Settings for Network Deployment and Administration
Network Deployment Principles and Considerations
Modifying Default Management Access Configuration Properties
Modifying Default Connectivity Configuration Properties
Example Setup of Dynamic DNS
Assigning System Identification Information
Setting Properties for SP or CMM Clock
Suggested Resolutions for Network Connectivity Issues
Using Remote KVMS Consoles for Host Server Redirection
First-Time Setup for Oracle ILOM Remote Console
Requirements for Using the Oracle ILOM Remote Console
Configure Local Client KVMS Settings
Register 32-Bit JDK Java Plug-In For Windows IE Web Browser
Register 32-Bit JDK Java Plug-In for Mozilla Firefox Web Browser
Optionally Set a Lock Mode to Secure the Host Server Desktop
Lock Host Desktop When Disconnecting a Remote KVMS Session
Launching and Using the Oracle ILOM Remote Console
Launch and Use the Oracle ILOM Remote Console
Toggle Key Sequence for Keyboard and Mouse Control
Redirection Menu Options
Devices Menu Options
Keyboard Menu Options
First Time Setup for Oracle ILOM Storage Redirection CLI
Requirements for Using the Oracle ILOM Storage Redirection CLI
Register Java Plug-In for Windows IE Browser and Start Service for First Time
Start Service For First Time and Register Java Plug-In for Mozilla Firefox Browser
Install the Storage Redirection Client
Optionally Modify the Default Network Port 2121 for Storage Redirection
Launching and Using the Oracle ILOM Storage Redirection CLI
Launch the Oracle ILOM Storage Redirection CLI and Redirect Storage Devices
Interactive and Non-Interactive Shell Syntax
Storage Redirection Commands and Options
Starting and Stopping a Host Serial Redirection Session
Start Serial Console Redirection and Log In to Host Server OS
Configuring Host Server Management Actions
Controlling Host Power to Server or Blade System Chassis
Setting Host Diagnostic Tests to Run
Setting Next Boot Device on x86 Host Server
Setting Boot Behavior on SPARC Host Server
Overriding SPARC Host Boot Mode
Managing SPARC Host Domains
Setting SPARC Host KeySwitch State
Setting SPARC Host TPM State
Setting Up Alert Notifications and Syslog Server for Event Logging
Configuring Alert Notifications
Configuring Syslog for Event Logging
Setting System Management Power Source Policies
Power-On and Cooling-Down Policies Configurable From the Server SP
System Management Power Supply Policies Configurable From CMM
Setting Power Alert Notifications and Managing System Power Usage
Setting Power Consumption Alert Notifications
Setting CMM Power Grant and SP Power Limit Properties
Setting SP Advanced Power Capping Policy to Enforce Power Limit
Setting SP Power Management Settings for Power Policy (SPARC)
Setting the CMM Power Supply Redundancy Policy
Performing Oracle ILOM Maintenance and Configuration Management Tasks
Performing Firmware Updates
Reset Power to Service Processor or Chassis Monitoring Module
Backing Up, Restoring, or Resetting the Oracle ILOM Configuration
Maintaining x86 BIOS Configuration Parameters
BIOS Configuration Management
Performing BIOS Configuration Tasks From Oracle ILOM
SAS Zoning Chassis Blade Storage Resources
Zone Management for Chassis-Level SAS-2 Capable Resources
Manageable SAS-2 Zoning-Capable Devices
Sun Blade Zone Manager Properties
Important SAS Zoning Allocations Considerations
Enabling Zoning and Creating SAS-2 Zoning Assignments
Managing Existing SAS-2 Storage Resource Allocations
Resetting Sun Blade Zone Manager Allocations to Factory Defaults
Resetting the Zoning Password to Factory Default for Third-Party In-Band Management
User's Guide
Oracle ILOM Overview
About Oracle ILOM
Oracle ILOM Features and Functionality
Supported Management Interfaces
Supported Operating System Web Browsers
Integration With Other Management Tools
Getting Started With Oracle ILOM 3.1
Navigating the Redesigned 3.1 Web Interface
Navigating the Command-Line Interface (CLI) Namespace Targets
Collecting System Information, Monitoring Health Status, and Initiating Host Management
Collecting Information, Status, and Initiating Common Actions
Administering Open Problems
Administering Service Actions: Sun Blade Chassis NEMs
Managing Oracle ILOM Log Entries
Performing Commonly Used Host Management Actions (Web)
Applying Host and System Management Actions
Administering Host Management Configuration Actions
Administering System Management Configuration Actions
Real-Time Power Monitoring Through Oracle ILOM Interfaces
Monitoring Power Consumption
Monitoring Power Allocations
Analyzing Power Usage Statistics
Comparing Power History Performance
Troubleshooting Oracle ILOM Managed Devices
Network Connection Issues: Oracle ILOM Interfaces
Tools for Observing and Debugging System Behavior
Enabling and Running Oracle ILOM Diagnostic Tools
Managing Sun Hardware Faults Through the Oracle ILOM Fault Management Shell
Protecting Against Hardware Faults: Oracle ILOM Fault Manager
Using fmadm to Administer Active Sun Hardware Faults
Using fmdump to View Historical Fault Management Logs
Using fmstat to View the Fault Management Statistics Report
Using the Command-Line Interface
About the Command-Line Interface (CLI)
CLI Reference For Supported DMTF Syntax, Command Verbs, Options
CLI Reference For Executing Commands to Change Properties
CLI Reference For Mapping Management Tasks to CLI Targets
CLI Reference
Basic CLI Command Reference for Oracle ILOM 3.1
System Information and Management
Host and System Control
Oracle ILOM Initial Setup
System Monitoring and Status
System Inventory
Oracle ILOM Configuration Management
Oracle ILOM Help
SNMP, IPMI, CIM, WS-MAN Protocol Management
SNMP Overview
About Simple Network Management Protocol
SNMP Components
Oracle ILOM SNMP MIBs
Configuring SNMP Settings in Oracle ILOM
Managing SNMP Read and Write Access, User Accounts, and SNMP Trap Alerts (CLI)
Managing SNMP Read and Write Access, User Accounts, and SNMP Trap Alerts (Web)
Downloading SNMP MIBs Using Oracle ILOM
Manage User Accounts Using SNMP
Before You Begin – User Accounts (SNMP)
Configuring Oracle ILOM User Accounts (SNMP)
Configuring Oracle ILOM for Active Directory (SNMP)
Manage DNS Name Server Settings (SNMP)
Configuring Oracle ILOM for LDAP (SNMP)
Configuring Oracle ILOM for LDAP/SSL (SNMP)
Configuring Oracle ILOM for RADIUS (SNMP)
Manage Component Information and Email Alerts (SNMP)
Before You Begin – Component Information (SNMP)
Viewing Component Information (SNMP)
Managing Clock Settings, Event Log, Syslog Receiver, and Alert Rules (SNMP)
Configuring SMTP Client for Email Alert Notifications (SNMP)
Configuring Email Alert Settings (SNMP)
Configuring Telemetry Harness Daemon (SNMP)
Monitor and Manage System Power (SNMP)
Before You Begin – Power Management (SNMP)
Monitoring the Power Consumption Interfaces (SNMP)
Maintaining System Power Policy (SNMP)
Managing System Power Properties (SNMP)
Manage Oracle ILOM Firmware Updates (SNMP)
Update Oracle ILOM Firmware (SNMP)
Manage Oracle ILOM Backup and Restore Configurations (SNMP)
View and Configure Backup and Restore Properties (SNMP)
Manage SPARC Diagnostics, POST, and Boot Mode Operations (SNMP)
Before You Begin – Manage SPARC Hosts (SNMP)
Managing SPARC Diagnostic, POST, and Boot Mode Properties (SNMP)
Server Managment Using IPMI
Intelligent Platform Management Interface (IPMI)
Configuring the IPMI Service
Using IPMItool to Run ILOM CLI Commands
Performing System Management Tasks (IPMItool)
IPMItool Utility and Command Summary
Server Management Using WS-Management and CIM
WS-Management and CIM Overview
Configuring Support for WS-Management in Oracle ILOM
Supported DMTF SMASH Profiles, CIM Classes and CIM Indications
Oracle's Sun-Supported CIM Classes
Document Conventions for Oracle's Sun-Supported CIM Classes
Oracle_AssociatedIndicatorLED
Oracle_AssociatedSensor
Oracle_Chassis
Oracle_ComputerSystem
Oracle_ComputerSystemPackage
Oracle_Container
Oracle_ElementCapabilities
Oracle_ElementConformsToProfile
Oracle_EnabledLogicalElementCapabilities
Oracle_HWCompErrorOkIndication
Oracle_IndicatorLED
Oracle_InstCreation
Oracle_InstDeletion
Oracle_LogEntry
Oracle_LogManagesRecord
Oracle_Memory
Oracle_NumericSensor
Oracle_PhysicalAssetCapabilities
Oracle_PhysicalComponent
Oracle_PhysicalElementCapabilities
Oracle_PhysicalMemory
Oracle_PhysicalPackage
Oracle_Processor
Oracle_ProcessorChip
Oracle_Realizes
Oracle_RegisteredProfile
Oracle_RecordLog
Oracle_ReferencedProfile
Oracle_Sensor
Oracle_SpSystemComponent
Oracle_SystemDevice
Oracle_ThresholdIndication
Oracle_UseOfLog
SNMP Command Examples
snmpget Command
snmpwalk Command
snmpbulkwalk Command
snmptable Command
snmpset Command
snmptrapd Command
Feature Updates and Release Notes
Feature Enhancements as of Oracle ILOM 3.1
Feature Enhancements Summary
Updates to Oracle ILOM 3.1.x Firmware
Initial 3.1 Point Releases for Servers and Sun Blade 6000 CMM
Oracle ILOM 3.1 Known Issues
Deprecation Notice for WS-Man as of Oracle ILOM 3.2.1
Documentation Titles in Translated Documents
Glossary
Index
Perform this procedure to: (1) register the 32-bit JDK Java plug-in with the Microsoft Windows IE browser, and (2) to start the storage redirection service for the first time:.
  1. On the local Windows client, open Windows Explorer (not Internet Explorer).
  2. In the Windows Explorer dialog box, click Tools > Folder Options, and then click the Files Types tab.
  3. In the Files Types tab, do the following:
    1. In the Registered File Type list, select the JNLP file type and click Change.
    2. In the Open With dialog box, click Browse to select the 32-bit JDK file stored on the local client system.
    3. Enable the check box for “Always use the selected program to open this kind of file.”
    4. Click OK.
  4. To start the storage redirection service for first time, open the Oracle ILOM web interface, and then click Remote Control > Redirection > Launch Service.
    The Opening Jnlpgenerator-cli dialog box appears.
  5. In the Opening Jnlpgenerator-cli dialog box, choose one of the following options to either install the file or run it from the web interface:
    • Install – Click “Save to disk,” specify a storage file location, and then click OK.
    • Run – Click “Open it with” and choose the javaws (default) 32-bit JDK file on the local system, and then click OK. A security warning dialog box appears prior to running the Storage Redirection service.
    Special Considerations:
    • If you chose to run the Jnlpgenerator-cli file instead of installing the file, subsequent users will need to start the storage redirection service from the Oracle ILOM web interface prior to using the Oracle ILOM Storage Redirection CLI console.
    • If you chose to run the Jnlpgenerator-cli file, and you also chose to enable the check box for “Always perform this action when handling this file type,” the Jnlpgenerator-cli dialog box will become unavailable in the future to modify the default storage network port. Therefore, if in the future the default network port (2121) needs to be modified, you should not enable this check box.
  6. Start the storage redirection service by performing one of the following:
    • Run Service – In the Security dialog box, click Run (or Yes) to start the service.
    • Start service from command window or terminal – Type the location of the installed Jnlpgenerator-cli file, followed by the javaws rconsole.jnlp command to start the service
      Example Syntax:
      cd jnlp file location javaws rconsole.jnlp
      If the storage redirection service fails to start, an error message appears informing you of an error condition. Otherwise, if an error message did not appear, the service is started and is waiting for user input.
