Skip Navigation Links
Exit Print View
Oracle Integrated Lights Out Manager (ILOM) 3.1 Documentation Collection
search filter icon
search icon
Document Information
Using This Documentation
Related Documentation
Documentation Feedback
Product Downloads
Download Product Software and Firmware
Oracle ILOM 3.1 Firmware Version Numbering Scheme
Support and Accessibility
Quick Start
Oracle ILOM 3.1 – Quick Start
Factory Default Settings
Mandatory Setup Tasks
Optional Setup Tasks
Daily Management Tasks
Routine Maintenance Tasks
Initial Setup FAQs
Configuration and Maintenance
Setting Up a Management Connection to Oracle ILOM and Logging In
Establishing a Management Connection to Oracle ILOM
Logging In to Oracle ILOM Server SP or CMM
Configuring Oracle ILOM for Maximum Security
Setting Up and Maintaining User Accounts
Managing User Credentials
Configuring Local User Accounts
Configuring Active Directory
Configuring LDAP/SSL
Configuring LDAP
Configuring RADIUS
Modifying Default Settings for Network Deployment and Administration
Network Deployment Principles and Considerations
Modifying Default Management Access Configuration Properties
Modifying Default Connectivity Configuration Properties
Example Setup of Dynamic DNS
Assigning System Identification Information
Setting Properties for SP or CMM Clock
Suggested Resolutions for Network Connectivity Issues
Using Remote KVMS Consoles for Host Server Redirection
First-Time Setup for Oracle ILOM Remote Console
Launching and Using the Oracle ILOM Remote Console
First Time Setup for Oracle ILOM Storage Redirection CLI
Launching and Using the Oracle ILOM Storage Redirection CLI
Starting and Stopping a Host Serial Redirection Session
Configuring Host Server Management Actions
Controlling Host Power to Server or Blade System Chassis
Setting Host Diagnostic Tests to Run
Setting Next Boot Device on x86 Host Server
Setting Boot Behavior on SPARC Host Server
Overriding SPARC Host Boot Mode
Managing SPARC Host Domains
Setting SPARC Host KeySwitch State
Setting SPARC Host TPM State
Setting Up Alert Notifications and Syslog Server for Event Logging
Configuring Alert Notifications
Configuring Syslog for Event Logging
Setting System Management Power Source Policies
Power-On and Cooling-Down Policies Configurable From the Server SP
System Management Power Supply Policies Configurable From CMM
Setting Power Alert Notifications and Managing System Power Usage
Setting Power Consumption Alert Notifications
Setting CMM Power Grant and SP Power Limit Properties
Setting SP Advanced Power Capping Policy to Enforce Power Limit
Setting SP Power Management Settings for Power Policy (SPARC)
Setting the CMM Power Supply Redundancy Policy
Performing Oracle ILOM Maintenance and Configuration Management Tasks
Performing Firmware Updates
Reset Power to Service Processor or Chassis Monitoring Module
Backing Up, Restoring, or Resetting the Oracle ILOM Configuration
Maintaining x86 BIOS Configuration Parameters
BIOS Configuration Management
Oracle ILOM: BIOS Configuration Features
Oracle ILOM: BIOS Special Considerations
Oracle ILOM: BIOS Terminology
Web and CLI: BIOS Properties
Performing BIOS Configuration Tasks From Oracle ILOM
Requirements for BIOS Configuration Tasks
View the BIOS Configuration Sync Status and Sync the Configuration Parameters
Reset BIOS Configuration to Factory Defaults
Reset Factory Defaults for SP and Oracle ILOM BIOS
Back Up the BIOS Configuration
Restore BIOS Configuration
SAS Zoning Chassis Blade Storage Resources
Zone Management for Chassis-Level SAS-2 Capable Resources
Manageable SAS-2 Zoning-Capable Devices
Sun Blade Zone Manager Properties
Important SAS Zoning Allocations Considerations
Enabling Zoning and Creating SAS-2 Zoning Assignments
Managing Existing SAS-2 Storage Resource Allocations
Resetting Sun Blade Zone Manager Allocations to Factory Defaults
Resetting the Zoning Password to Factory Default for Third-Party In-Band Management
User's Guide
Oracle ILOM Overview
About Oracle ILOM
Oracle ILOM Features and Functionality
Supported Management Interfaces
Supported Operating System Web Browsers
Integration With Other Management Tools
Getting Started With Oracle ILOM 3.1
Navigating the Redesigned 3.1 Web Interface
Navigating the Command-Line Interface (CLI) Namespace Targets
Collecting System Information, Monitoring Health Status, and Initiating Host Management
Collecting Information, Status, and Initiating Common Actions
Administering Open Problems
Administering Service Actions: Sun Blade Chassis NEMs
Managing Oracle ILOM Log Entries
Performing Commonly Used Host Management Actions (Web)
Applying Host and System Management Actions
Administering Host Management Configuration Actions
Administering System Management Configuration Actions
Real-Time Power Monitoring Through Oracle ILOM Interfaces
Monitoring Power Consumption
Monitoring Power Allocations
Analyzing Power Usage Statistics
Comparing Power History Performance
Troubleshooting Oracle ILOM Managed Devices
Network Connection Issues: Oracle ILOM Interfaces
Tools for Observing and Debugging System Behavior
Enabling and Running Oracle ILOM Diagnostic Tools
Managing Sun Hardware Faults Through the Oracle ILOM Fault Management Shell
Protecting Against Hardware Faults: Oracle ILOM Fault Manager
Using fmadm to Administer Active Sun Hardware Faults
Using fmdump to View Historical Fault Management Logs
Using fmstat to View the Fault Management Statistics Report
Using the Command-Line Interface
About the Command-Line Interface (CLI)
CLI Reference For Supported DMTF Syntax, Command Verbs, Options
CLI Reference For Executing Commands to Change Properties
CLI Reference For Mapping Management Tasks to CLI Targets
CLI Reference
Basic CLI Command Reference for Oracle ILOM 3.1
System Information and Management
Host and System Control
Oracle ILOM Initial Setup
System Monitoring and Status
System Inventory
Oracle ILOM Configuration Management
Oracle ILOM Help
SNMP, IPMI, CIM, WS-MAN Protocol Management
SNMP Overview
About Simple Network Management Protocol
SNMP Components
Oracle ILOM SNMP MIBs
Configuring SNMP Settings in Oracle ILOM
Managing SNMP Read and Write Access, User Accounts, and SNMP Trap Alerts (CLI)
Managing SNMP Read and Write Access, User Accounts, and SNMP Trap Alerts (Web)
Downloading SNMP MIBs Using Oracle ILOM
Manage User Accounts Using SNMP
Before You Begin – User Accounts (SNMP)
Configuring Oracle ILOM User Accounts (SNMP)
Configuring Oracle ILOM for Active Directory (SNMP)
Manage DNS Name Server Settings (SNMP)
Configuring Oracle ILOM for LDAP (SNMP)
Configuring Oracle ILOM for LDAP/SSL (SNMP)
Configuring Oracle ILOM for RADIUS (SNMP)
Manage Component Information and Email Alerts (SNMP)
Before You Begin – Component Information (SNMP)
Viewing Component Information (SNMP)
Managing Clock Settings, Event Log, Syslog Receiver, and Alert Rules (SNMP)
Configuring SMTP Client for Email Alert Notifications (SNMP)
Configuring Email Alert Settings (SNMP)
Configuring Telemetry Harness Daemon (SNMP)
Monitor and Manage System Power (SNMP)
Before You Begin – Power Management (SNMP)
Monitoring the Power Consumption Interfaces (SNMP)
Maintaining System Power Policy (SNMP)
Managing System Power Properties (SNMP)
Manage Oracle ILOM Firmware Updates (SNMP)
Update Oracle ILOM Firmware (SNMP)
Manage Oracle ILOM Backup and Restore Configurations (SNMP)
View and Configure Backup and Restore Properties (SNMP)
Manage SPARC Diagnostics, POST, and Boot Mode Operations (SNMP)
Before You Begin – Manage SPARC Hosts (SNMP)
Managing SPARC Diagnostic, POST, and Boot Mode Properties (SNMP)
Server Managment Using IPMI
Intelligent Platform Management Interface (IPMI)
Configuring the IPMI Service
Using IPMItool to Run ILOM CLI Commands
Performing System Management Tasks (IPMItool)
IPMItool Utility and Command Summary
Server Management Using WS-Management and CIM
WS-Management and CIM Overview
Configuring Support for WS-Management in Oracle ILOM
Supported DMTF SMASH Profiles, CIM Classes and CIM Indications
Oracle's Sun-Supported CIM Classes
Document Conventions for Oracle's Sun-Supported CIM Classes
Oracle_AssociatedIndicatorLED
Oracle_AssociatedSensor
Oracle_Chassis
Oracle_ComputerSystem
Oracle_ComputerSystemPackage
Oracle_Container
Oracle_ElementCapabilities
Oracle_ElementConformsToProfile
Oracle_EnabledLogicalElementCapabilities
Oracle_HWCompErrorOkIndication
Oracle_IndicatorLED
Oracle_InstCreation
Oracle_InstDeletion
Oracle_LogEntry
Oracle_LogManagesRecord
Oracle_Memory
Oracle_NumericSensor
Oracle_PhysicalAssetCapabilities
Oracle_PhysicalComponent
Oracle_PhysicalElementCapabilities
Oracle_PhysicalMemory
Oracle_PhysicalPackage
Oracle_Processor
Oracle_ProcessorChip
Oracle_Realizes
Oracle_RegisteredProfile
Oracle_RecordLog
Oracle_ReferencedProfile
Oracle_Sensor
Oracle_SpSystemComponent
Oracle_SystemDevice
Oracle_ThresholdIndication
Oracle_UseOfLog
SNMP Command Examples
snmpget Command
snmpwalk Command
snmpbulkwalk Command
snmptable Command
snmpset Command
snmptrapd Command
Feature Updates and Release Notes
Feature Enhancements as of Oracle ILOM 3.1
Feature Enhancements Summary
Updates to Oracle ILOM 3.1.x Firmware
Initial 3.1 Point Releases for Servers and Sun Blade 6000 CMM
Oracle ILOM 3.1 Known Issues
Deprecation Notice for WS-Man as of Oracle ILOM 3.2.1
Documentation Titles in Translated Documents
Glossary
Index
Table 71 BIOS Web Navigation and CLI Targets
Web Navigation
CLI Targets
System Management > BIOS
/System/BIOS
/System/BIOS/Config
Table 72 BIOS Web and CLI Properties
Property Name
Type
Value(s)
Description
System BIOS Version
(system_bios_version=)
Read-only
The system BIOS Version property identifies the version of the BIOS firmware that is currently installed on the managed Oracle x86 server.
BIOS Configuration: Sync Status
(config_sync_status=)
Read-only
OK|Reboot Required|Internal Error
The BIOS Configuration Sync Status property indicates one of the following states:
  • OK – The BIOS configuration parameters maintained by Oracle ILOM are in-sync with the configuration parameters in the BIOS non-volatile data store.
  • Reboot Required – The BIOS configuration parameters maintained by Oracle ILOM are out-of-sync with the configuration parameters in the BIOS non-volatile data store. The Oracle x86 server must be rebooted to sync the BIOS parameters.
  • Internal Error – Oracle ILOM is unable to read the BIOS non-volatile data store and is prevented from initiating a BIOS Backup or Restore operation. For further assistance, contact Oracle Service.
BIOS Configuration: Reset To Defaults
(reset_to_defaults=)
Read|Write
Factory |None
The Reset To Defaults property provides one of the following values:
  • Factory – Sets the configuration parameters in the BIOS non-volatile data store to factory defaults.
  • None – This value (None) appears after resetting the parameters in the BIOS non-volatile data store to factory defaults.
BIOS Configuration: Backup
(dump_uri=)
Write-only
The BIOS Configuration Backup property enables you to create a copy of the parameters in the BIOS non-volatile data store and save those parameters to a BIOS Configuration file in the ILOM file system.
For instructions for backing up the BIOS configuration, see Back Up the BIOS Configuration .
BIOS Configuration: Restore Status
(restore_status=)
Read-only
OK | Restore pending |
Partial restore: invalid configuration entry |
Partial restore: invalid boot order entry |
Partial restore: invalid configuration and boot order entries
The BIOS Configuration Restore Status property indicates one of the following states:
  • OK – The last Restore operation succeeded for restoring the Oracle ILOM BIOS configuration parameters to the host BIOS non-volatile data store.
  • Restore pending – The Restore operation is pending a host power off. Note – The Restore operation is performed by Oracle ILOM when the host server is powered off.
  • Partial restore: invalid configuration entry – The last Restore operation failed to restore one or more of the host BIOS configuration parameters.
  • Partial restore: invalid boot order entry – The last Restore operation failed to restore one or more boot devices in the host boot order list.
  • Partial restore: invalid configuration and boot order entries – The last Restore operation failed to restore one or more BIOS configuration parameters and one or more boot devices in the host boot order list.
(load_uri= restore_options)
Read|Write
All| Configuration only| Bootlist only | Cancel Restore
The BIOS Configuration Restore property enables you to restore the BIOS parameters previously saved by Oracle ILOM to the host BIOS non-volatile data store. The options for restoring the BIOS parameters include:
  • All – Restores all BIOS configuration parameters that were previously saved by Oracle ILOM.
  • Configuration only – Restores the previously saved setup parameters.
  • Bootlist only – Restores the host boot list parameters previously saved by Oracle ILOM.
  • Cancel Restore (or action=cancel) – Cancels the initiated Restore operation.
Note - The Cancel Restore option in the web interface is only available if: (1) you initiated a Restore operation, and (2) the host operating system on the managed Oracle x86 server has not yet been powered down or reset.
For instructions for restoring the BIOS configuration, see Restore BIOS Configuration .
Transfer Method Options
Read|Write
Browser | TFTP| FTP |SFTP |SCP |HTTP |HTTPS
When importing or exporting the Oracle ILOM BIOS configuration parameters, you can specify one of the following transfer methods:
  • Browser – Web interface option only. This option enables you to specify the location of the file.
  • TFTP – This option enables you to specify the TFTP host IP address or name and the directory path to the file.
  • FTP – This option enables you to specify the host IP address or name, user name and password for the FTP server, as well as the directory path to the file location.
  • SFTP – This option enables you to specify the host IP address or name, username and password for the SFTP server, as well as the directory path to the file location.
  • SCP – This option enables you to specify the host network address, user name and password for the SCP server, as well as the directory path to the file location.
  • HTTP – This option enables you to specify the host network address, username and password for the HTTP server, as well as the directory path to the file location.
  • HTTPS – This option enables you to specify the host network IP address or name, user name and password for the HTTPS server, as well as the directory path to the file location.
Table 73 -force Option for CLI Commands: load and dump
load_uri=-force restore_option/transfer_method://username:password@ipaddress_or_hostname/directorypath/filename
dump_uri=-force transfer_method://username:password@ipaddress_or_hostname/directorypath/filename
Usage – You must specify the -force option to prevent the load or dump command from failing when: (1) a “Pending Restore” state appears for Restore Status (restore_status=pending_restore) or (2) when a “Reboot Needed” state appears for BIOS Configuration Sync (config_sync_status=reboot_needed).
Caution
Caution - An out-of-sync version of the host BIOS Configuration file is copied to the Oracle ILOM file system when: (1) a “Reboot Needed” state appears for BIOS Configuration Sync (sync_status=reboot_needed) and (2) the dump_uri=-force option is used to back up the BIOS Configuration file.
Caution
Caution - The parameters in an existing pending restore BIOS Configuration file are replaced with the parameters from the last Backup BIOS Configuration file when: (1) a “Restore Pending” state appears for Restore Status (restore_status=restore_pending) and (2) the load_uri=-force option is used to restore the parameters in the host BIOS non-volatile data store.
