Skip Navigation Links
Exit Print View
Oracle Integrated Lights Out Manager (ILOM) 3.1 Documentation Collection
search filter icon
search icon
Document Information
Using This Documentation
Related Documentation
Documentation Feedback
Product Downloads
Download Product Software and Firmware
Oracle ILOM 3.1 Firmware Version Numbering Scheme
Support and Accessibility
Quick Start
Oracle ILOM 3.1 – Quick Start
Factory Default Settings
Mandatory Setup Tasks
Optional Setup Tasks
Daily Management Tasks
Routine Maintenance Tasks
Initial Setup FAQs
Configuration and Maintenance
Setting Up a Management Connection to Oracle ILOM and Logging In
Establishing a Management Connection to Oracle ILOM
Logging In to Oracle ILOM Server SP or CMM
Configuring Oracle ILOM for Maximum Security
Setting Up and Maintaining User Accounts
Managing User Credentials
Configuring Local User Accounts
Configuring Active Directory
Configuring LDAP/SSL
Configuring LDAP
Configuring RADIUS
Modifying Default Settings for Network Deployment and Administration
Network Deployment Principles and Considerations
Modifying Default Management Access Configuration Properties
Modifying Default Connectivity Configuration Properties
Example Setup of Dynamic DNS
Assigning System Identification Information
Setting Properties for SP or CMM Clock
Suggested Resolutions for Network Connectivity Issues
Using Remote KVMS Consoles for Host Server Redirection
First-Time Setup for Oracle ILOM Remote Console
Launching and Using the Oracle ILOM Remote Console
First Time Setup for Oracle ILOM Storage Redirection CLI
Launching and Using the Oracle ILOM Storage Redirection CLI
Starting and Stopping a Host Serial Redirection Session
Host Serial Console Log Properties
Configuring Host Server Management Actions
Controlling Host Power to Server or Blade System Chassis
Setting Host Diagnostic Tests to Run
Setting Next Boot Device on x86 Host Server
Setting Boot Behavior on SPARC Host Server
Overriding SPARC Host Boot Mode
Managing SPARC Host Domains
Setting SPARC Host KeySwitch State
Setting SPARC Host TPM State
Setting Up Alert Notifications and Syslog Server for Event Logging
Configuring Alert Notifications
Alert Notification Configuration Properties
Configure and Test Alert Notification (IPMI PET, SNMP, or Email)
Disable Alert Notification (IPMI PET, SNMP, or Email)
Configure SMTP Client for Email Alerts
Configuring Syslog for Event Logging
Configure Syslog IP Address for Event Logging
Setting System Management Power Source Policies
Power-On and Cooling-Down Policies Configurable From the Server SP
System Management Power Supply Policies Configurable From CMM
Setting Power Alert Notifications and Managing System Power Usage
Setting Power Consumption Alert Notifications
Setting CMM Power Grant and SP Power Limit Properties
Setting SP Advanced Power Capping Policy to Enforce Power Limit
Setting SP Power Management Settings for Power Policy (SPARC)
Setting the CMM Power Supply Redundancy Policy
Performing Oracle ILOM Maintenance and Configuration Management Tasks
Performing Firmware Updates
Reset Power to Service Processor or Chassis Monitoring Module
Backing Up, Restoring, or Resetting the Oracle ILOM Configuration
Maintaining x86 BIOS Configuration Parameters
BIOS Configuration Management
Performing BIOS Configuration Tasks From Oracle ILOM
SAS Zoning Chassis Blade Storage Resources
Zone Management for Chassis-Level SAS-2 Capable Resources
Manageable SAS-2 Zoning-Capable Devices
Sun Blade Zone Manager Properties
Important SAS Zoning Allocations Considerations
Enabling Zoning and Creating SAS-2 Zoning Assignments
Managing Existing SAS-2 Storage Resource Allocations
Resetting Sun Blade Zone Manager Allocations to Factory Defaults
Resetting the Zoning Password to Factory Default for Third-Party In-Band Management
User's Guide
Oracle ILOM Overview
About Oracle ILOM
Oracle ILOM Features and Functionality
Supported Management Interfaces
Supported Operating System Web Browsers
Integration With Other Management Tools
Getting Started With Oracle ILOM 3.1
Navigating the Redesigned 3.1 Web Interface
Navigating the Command-Line Interface (CLI) Namespace Targets
Collecting System Information, Monitoring Health Status, and Initiating Host Management
Collecting Information, Status, and Initiating Common Actions
Administering Open Problems
Administering Service Actions: Oracle Blade Chassis NEMs
Managing Oracle ILOM Log Entries
Performing Commonly Used Host Management Actions (Web)
Applying Host and System Management Actions
Administering Host Management Configuration Actions
Administering System Management Configuration Actions
Troubleshooting Oracle ILOM Managed Devices
Network Connection Issues: Oracle ILOM Interfaces
Tools for Observing and Debugging System Behavior
Enabling and Running Oracle ILOM Diagnostic Tools
Real-Time Power Monitoring Through Oracle ILOM Interfaces
Monitoring Power Consumption
Monitoring Power Allocations
Analyzing Power Usage Statistics
Comparing Power History Performance
Managing Oracle Hardware Faults Through the Oracle ILOM Fault Management Shell
Protecting Against Hardware Faults: Oracle ILOM Fault Manager
Using fmadm to Administer Active Oracle Hardware Faults
Using fmdump to View Historical Fault Management Logs
Using fmstat to View the Fault Management Statistics Report
Using the Command-Line Interface
About the Command-Line Interface (CLI)
CLI Reference For Supported DMTF Syntax, Command Verbs, Options
CLI Reference For Executing Commands to Change Properties
CLI Reference For Mapping Management Tasks to CLI Targets
CLI Reference
Basic CLI Command Reference for Oracle ILOM 3.1
System Information and Management
Host and System Control
Oracle ILOM Initial Setup
System Monitoring and Status
System Inventory
Oracle ILOM Configuration Management
Oracle ILOM Help
SNMP, IPMI, CIM, WS-MAN Protocol Management
SNMP Overview
About Simple Network Management Protocol
SNMP Components
SNMP Command-Line Syntax Examples
Configuring SNMP Settings in Oracle ILOM
Managing SNMP Read and Write Access, User Accounts, and SNMP Trap Alerts (CLI)
Managing SNMP Read and Write Access, User Accounts, and SNMP Trap Alerts (Web)
Downloading SNMP MIBs Using Oracle ILOM
Manage User Accounts Using SNMP
Before You Begin – User Accounts (SNMP)
Configuring Oracle ILOM User Accounts (SNMP)
Configuring Oracle ILOM for Active Directory (SNMP)
Manage DNS Name Server Settings (SNMP)
Configuring Oracle ILOM for LDAP (SNMP)
Configuring Oracle ILOM for LDAP/SSL (SNMP)
Configuring Oracle ILOM for RADIUS (SNMP)
Manage Component Information and Email Alerts (SNMP)
Before You Begin – Component Information (SNMP)
Viewing Component Information (SNMP)
Managing Clock Settings, Event Log, Syslog Receiver, and Alert Rules (SNMP)
Configuring SMTP Client for Email Alert Notifications (SNMP)
Configuring Email Alert Settings (SNMP)
Monitor and Manage System Power (SNMP)
Before You Begin – Power Management (SNMP)
Monitoring the Power Consumption Interfaces (SNMP)
Maintaining System Power Policy (SNMP)
Managing System Power Properties (SNMP)
Manage Oracle ILOM Firmware Updates (SNMP)
Update Oracle ILOM Firmware (SNMP)
Manage Oracle ILOM Backup and Restore Configurations (SNMP)
View and Configure Backup and Restore Properties (SNMP)
Manage SPARC Diagnostics, POST, and Boot Mode Operations (SNMP)
Before You Begin – Manage SPARC Hosts (SNMP)
Managing SPARC Diagnostic, POST, and Boot Mode Properties (SNMP)
Server Managment Using IPMI
Intelligent Platform Management Interface (IPMI)
Configuring the IPMI Service
Using IPMItool to Run ILOM CLI Commands
Performing System Management Tasks (IPMItool)
IPMItool Utility and Command Summary
Server Management Using WS-Management and CIM
WS-Management and CIM Overview
Configuring Support for WS-Management in Oracle ILOM
Supported DMTF SMASH Profiles, CIM Classes and CIM Indications
Oracle's Sun-Supported CIM Classes
Document Conventions for Oracle's Sun-Supported CIM Classes
SNMP Command Examples
snmpget Command
snmpwalk Command
snmpbulkwalk Command
snmptable Command
snmpset Command
snmptrapd Command
Feature Updates and Release Notes
Feature Enhancements as of Oracle ILOM 3.1
Feature Enhancements Summary
Updates to Oracle ILOM 3.1.x Firmware
Initial 3.1 Point Releases for Servers and Sun Blade 6000 CMM
Deprecation Notice for WS-Man as of Oracle ILOM 3.2.1
Oracle ILOM 3.1 Known Issues
Documentation Titles in Translated Documents
For each alert notification, Oracle ILOM requires these three properties to be set: alert type, alert destination, and alert level. Depending on which alert type is configured, other properties are optionally configurable.
For further details about the configuration properties for alert notifications, see the following table.
Table 68 Alert Notification Configuration Properties
Alert Type
The alert type property specifies the message format and the delivery method that Oracle ILOM will use when creating and sending the alert message.
Alert type choices include:
  • IPMI PET AlertsRequired properties include: alert destination IP address and an alert level. Each specified alert destination must support the receipt of IPMI PET messages.
  • SNMP Trap Alerts – Required property includes: alert destination IP address, alert destination port number, and an alert level. Each specified destination must support the receipt of SNMP Trap messages.
  • Email AlertsRequired properties include: destination email address and alert level. Prior to enabling Email alerts, properties for the SMTP email server must be configured in Oracle ILOM.
Related Information:
Alert Destination
The Alert Destination property specifies where to send the alert message. IP address destinations must be configured for IPMI PET and SNMP alerts. Email address destinations must be configured for Email alerts.
Alert Destination Port
The TCP/UDP destination port only applies to SNMP alert configurations.
Oracle ILOM automatically selects a standard TCP/UDP destination port number. System administrators can optionally choose to accept the standard (162) port number or manually specify a TCP/UDP port number.
Alert Level
All alert notification configurations require setting an alert level.
Alert levels enable the sending of the alert notification. In addition, for IPMI PET alerts and Email alerts, alert levels act as a filter mechanism to ensure alert recipients only receive the alert messages that they are most interested in receiving.
Oracle ILOM offers the following alert levels with Minor being the lowest alert offered:
  • Minor – Generates alerts for informational events, as well as major and critical events.
  • Major – Generates alerts for all non-critical, non-recoverable, and critical events.
  • Critical – Generates alerts for all critical and non-recoverable events.
  • Disabled – Disables the alert configuration. Oracle ILOM will not generate an alert message.
Important - Oracle ILOM supports alert level filtering for all IPMI PET alert configurations and Email alert configurations. Oracle ILOM does not support alert level filtering for SNMP alert configurations. However, to enable Oracle ILOM to generate an SNMP alert, one of the following alert levels must be specified: Minor, Major, or Critical.
Email Custom Sender
Optional for Email Alerts
System administrators can optionally configure this property for Email alert configurations only.
The email_custom_sender property enables Oracle ILOM to override the SMPT customer sender address by using one of the following strings: <IPADDRESS> or <HOSTNAME>.
Example: alert@<IPADDRESS>.
Email Message Prefix
The Email Message Prefix property enables Oracle ILOM to prepend user-specified information to the message body.
Event Class Filter
The Event Class Filter property enables Oracle ILOM to filter out all information except the selected event class. To clear the filter and send information about all classes, enter empty double quotes (““).
Event Type Filter
The Event Type Filter property enables Oracle ILOM to filter out all information except the selected event type. To clear the filter and send information about all event types, enter empty double quotes (““).
SNMP Version
Optional for SNMP Alerts
The SNMP Version property enables system administrators to specify the SNMP trap version being sent. Supported SNMP versions include: 1, 2c, or 3.
SNMP Community Name
User Name
System administrators can optionally specify an SNMPv1 or 2c community string or an SNMPv3 user name.
Note - If an SNMPv3 user name is configured, the SNMPv3 user name must be configured in Oracle ILOM. If the SNMP user name is not configured, the alert will not be authenticated for delivery.
