Skip Navigation Links
Exit Print View
Netra SPARC T4-1B Server Module HTML Document Collection
search filter icon
search icon
Document Information
Using This Documentation
Related Documentation
Feedback
Support and Accessibility
Installation
Understanding the Server Module
Installation Task Overview
Server Module Overview
Front and Rear Panel Components
Confirming Server Module and Site Specifications
Physical Specifications
Environmental Specifications
Electrical Specifications
Preparing for Installation
Inventory
Handling Precautions
ESD Precautions
Tools Needed for Installation
Plan Communication With the Server Module During Installation
Dongle Cables
Installing the Server Module
Prepare the Modular System and Server Module
Install Optional Components
Insert the Server Module Into the Chassis
Powering On the Server Module for the First Time
Method 1a – Power On the Host Through the CMM (Web Interface)
Method 1b – Power On the Host Through the CMM (CLI)
Method 2 – Power On the Host Through the CMM SER MGT Port (CLI)
Method 3 – Power On the Host Through the Front Panel (SP CLI)
Configuring the Oracle Solaris OS
Configure the OS
Install Oracle Solaris Software From the Network
Oracle Solaris Configuration Parameters
Assign a Static IP Address to the SP
Administration
Understanding System Administration Resources
Oracle ILOM Overview
Platform-Specific Oracle ILOM Features
Oracle Solaris OS Overview
OpenBoot Overview
Oracle VM Server for SPARC Overview
Multipathing Software
Hardware Management Pack Overview
Source for Downloading Hardware Management Pack Software
Hardware Management Pack Documentation
Accessing the Server
Log In to Oracle ILOM
Log In to the System Console
Display the ok Prompt
Display the Oracle ILOM -> Prompt
Use a Local Graphics Monitor
Oracle ILOM Remote Console
Controlling the Server
Power On the Server (Oracle ILOM)
Power Off the Server (Oracle ILOM)
Reset the Server (Oracle Solaris OS)
Reset the Server (Oracle ILOM)
Reset the SP to Default Values
Configuring Hardware RAID
Hardware RAID Support
Important Hardware RAID Guidelines
Prepare to Use the FCode Utility
FCode Utility Commands
Create a Hardware RAID Volume
Hot Spare Drives in RAID Volumes (LSI)
Determining If a Drive Has Failed
Service Required Drive LEDs
Error Messages (System Console and Log Files)
Display Status (show-volumes Command, OBP)
Display Status (sas2ircu Utility, LSI)
RAID Drive Replacement Strategies
Locate Device Paths
Changing Server Identification Information
Change Customer Data on FRU PROMs
Change System Identifier Information
Configuring Policy Settings
Specify Cooldown Mode
Restore the Host Power State at Restart
Specify the Host Power State at Restart
Disable or Re-Enable the Host Power-On Delay
Specify Parallel Boot of the SP and Host
Configure Host Behavior (Keyswitch State)
Configuring Network Addresses
SP Network Address Options
Disable or Re-Enable Network Access to the SP
Display the DHCP Server IP Address
Display the IP Address of the SP
Display the Host MAC Address
Using an In-band Connection to the SP
Configuring Boot Mode
Boot Mode Overview
Configure the Host Boot Mode (Oracle VM Server for SPARC)
Change the Host Boot Mode Behavior at Reset
Manage the Host Boot Mode Script
Display Host Boot Mode Expiration Date
Override OBP Settings to Reset the Server
Configuring Server Behavior at Restart
Specify Behavior When the Host Resets
Specify Behavior When the Host Stops Running
Set the Boot Timeout Interval
Specify Behavior at Boot Timeout
Specify Behavior if Restart Fails
Specify Maximum Restart Attempts
Configuring Devices
Unconfigure a Device Manually
Reconfigure a Device Manually
Monitoring the Server
Monitoring Faults
Enabling Automatic System Recovery
Display Server Components
Locate the Server
Updating the Firmware
Display the Firmware Version
Update the Firmware
Display OpenBoot Version
Display POST Version
Identifying WWN-Designated SAS2 Devices
World Wide Name Syntax
Mapping WWN Values to Hard Drives (OBP probe-scsi-all Command)
Identify a Disk Slot Using prtconf (Oracle Solaris OS)
WWN Syntax in an OS Installation on an Individual Drive
WWN Syntax in an OS Installation on a RAID Volume
Service
Identifying Components
Illustrated Parts Breakdown
Detecting and Managing Faults
Diagnostics Overview
Diagnostics Process
Diagnostics LEDs
Managing Faults (Oracle ILOM)
Interpreting Log Files and System Messages
Checking if Oracle VTS Software Is Installed
Managing Faults (POST)
Managing Faults (PSH)
Managing Components (ASR)
Preparing for Service
Safety Information
Tools Needed for Service
Find the Modular System Chassis Serial Number
Find the Server Module Serial Number
Locate the Server Module
Preparing the Server Module for Removal
Remove the Server Module From the Modular System
Remove the Cover
Servicing Drives
Drive Configuration
Drive LEDs
Drive Hot-Plugging Guidelines
Locate a Faulty Drive
Remove a Drive
Remove a Drive Filler
Install a Drive
Install a Drive Filler
Verify Drive Functionality
Servicing Memory
Memory Faults
DIMM Configuration
DIMM Handling Precautions
Locate a Faulty DIMM
Remove a DIMM
Install a DIMM
Clear the Fault and Verify the Functionality of the Replacement DIMM
Verify DIMM Functionality
Servicing the REM
Remove a REM
Install a REM
Servicing the FEM
Remove a FEM
Install a FEM
Servicing the SP Card
Remove the SP Card
Install the SP Card
Servicing the ID PROM
Remove the ID PROM
Install the ID PROM
Verify the ID PROM
Servicing a USB Flash Drive
Remove a USB Flash Drive
Install a USB Flash Drive
Servicing the Battery
Replace the Battery
Replacing the Server Module Enclosure Assembly (Motherboard)
Transfer Components to Another Enclosure Assembly
Returning the Server Module to Operation
Replace the Cover
Install the Server Module Into the Modular System
Power On the Host (Oracle ILOM)
Power On the Host (Power Button)
Glossary
Index
Locate Device Paths
Use this procedure to locate device paths specific to your server.
  1. Display the ok prompt.
    See Display the ok Prompt.
  2. From the ok prompt, type:
    Note - This example represents devalias output for a sample T4-x server. The specific devices displayed will differ for different products.
    {0} ok devalias
    screen                  /pci@400/pci@2/pci@0/pci@0/pci@0/display@0
    mouse                   /pci@400/pci@2/pci@0/pci@f/pci@0/usb@0,2/hub@2/device@4
    /mouse@1
    rcdrom                   /pci@400/pci@2/pci@0/pci@f/pci@0/usb@0,2/hub@2/hub@3
    /storage@2/disk@0
    rkeyboard                /pci@400/pci@2/pci@0/pci@f/pci@0/usb@0,2/hub@2/device@4
    /keyboard@0
    rscreen                  /pci@400/pci@2/pci@0/pci@0/pci@0/display@0:r1280x1024x60
    net3                     /pci@400/pci@2/pci@0/pci@7/network@0,1
    net2                     /pci@400/pci@2/pci@0/pci@7/network@0
    net1                     /pci@400/pci@2/pci@0/pci@6/network@0,1
    net0                     /pci@400/pci@2/pci@0/pci@6/network@0
    net                      /pci@400/pci@2/pci@0/pci@6/network@0
    disk7                    /pci@400/pci@2/pci@0/pci@4/scsi@0/disk@p3
    disk6                    /pci@400/pci@2/pci@0/pci@4/scsi@0/disk@p2
    disk5                    /pci@400/pci@2/pci@0/pci@4/scsi@0/disk@p1
    disk4                    /pci@400/pci@2/pci@0/pci@4/scsi@0/disk@p0
    cdrom                    /pci@400/pci@2/pci@0/pci@4/scsi@0/disk@p6
    scsi1                    /pci@400/pci@2/pci@0/pci@4/scsi@0
    disk3                    /pci@400/pci@1/pci@0/pci@4/scsi@0/disk@p3
    disk2                    /pci@400/pci@1/pci@0/pci@4/scsi@0/disk@p2
    disk1                    /pci@400/pci@1/pci@0/pci@4/scsi@0/disk@p1
    disk0                    /pci@400/pci@1/pci@0/pci@4/scsi@0/disk@p0
    disk                     /pci@400/pci@1/pci@0/pci@4/scsi@0/disk@p0
    scsi0                    /pci@400/pci@1/pci@0/pci@4/scsi@0
    scsi                     /pci@400/pci@1/pci@0/pci@4/scsi@0
    virtual-console          /virtual-devices@100/console@1
    name                     aliases
    {0} ok
Related Information
