Skip Navigation Links
Exit Print View
Sun Quad Port GbE PCIe 2.0 Low Profile Adapter, UTP
User's Guide
search filter icon
search icon
Document Information
Using This Documentation
Product Notes
Related Documentation
Feedback
Support and Accessibility
Understanding the Installation Process
Installation Overview (Oracle Solaris 10)
Installation Overview (Oracle Solaris 11)
Installation Overview (Linux)
Installation Overview (Windows)
Understanding the Adapter
Shipping Kit Contents
Product Description
Configuration Options
Front Panel Connectors and LEDs
Physical Characteristics
Performance Specifications
Power and Environmental Requirements
OS Patches and Updates
Installing the Driver
Verify the Driver Version (Oracle Solaris 10)
Verify the Driver Version (Oracle Solaris 11)
Remove the Driver (Oracle Solaris OS)
Download and Install the Driver (Linux)
Remove the Driver (Linux)
Download and Install the Driver (Windows)
Remove the Driver (Windows)
Installing the Adapter
Install the Adapter
Verify the Installation (Oracle SPARC)
Verify the Installation (Oracle Solaris x86)
Verify the Installation (Linux)
Verify the Installation (Windows)
Configuring the Network
Create Driver Instance Files (Oracle Solaris 10)
Configure the Network Host Files (Oracle Solaris 10)
Boot Options
Boot Over the Network (PXE)
Boot Over a GbE Network (Oracle Solaris x86 and Linux)
Install Oracle Solaris 10 Over a Network (Oracle SPARC)
Administering Driver Parameters and Jumbo Frames
Driver Parameters (Oracle Solaris OS)
Set Driver Parameters (Oracle Solaris OS)
Driver Parameters (Linux)
Set Driver Parameters (Linux)
Configuring Jumbo Frames (Oracle Solaris OS)
Change the MTU Permanently
Change the MTU Temporarily (Oracle Solaris 10)
Change the MTU Temporarily (Oracle Solaris 11)
Configure Jumbo Frames (Linux)
Configuring Link Aggregation
Link Aggregation Overview
Configure Link Aggregations (Oracle Solaris 10)
Display Information About Link Aggregations (Oracle Solaris 10)
Delete Link Aggregations (Oracle Solaris 10)
Configuring VLANs
VLAN Overview
VLAN Configuration
VLAN Naming Format
Configure Static VLANs (Oracle Solaris 10)
Configure VLANs (Linux)
Configure VLANs (Windows)
Troubleshooting the Adapter
Analyze Why the Device Link Is Missing
Analyze a Port Hang
Analyze Slow Network Performance
Glossary
Index
These topics provide an overview of the installation process for the Sun Quad Port GbE PCIe 2.0 Low Profile Adapter, UTP:
Related Information
