Understanding the Installation Process
Installation Overview (Oracle Solaris 10)
Installation Overview (Oracle Solaris 11)
Installation Overview (Windows)
Front Panel Connectors and LEDs
Power and Environmental Requirements
Verify the Driver Version (Oracle Solaris 10)
Verify the Driver Version (Oracle Solaris 11)
Remove the Driver (Oracle Solaris OS)
Download and Install the Driver (Linux)
Download and Install the Driver (Windows)
Verify the Installation (Oracle Solaris x86)
Verify the Installation (Linux)
Verify the Installation (Windows)
Create Driver Instance Files (Oracle Solaris 10)
Configure the Network Host Files (Oracle Solaris 10)
Boot Over a GbE Network (Oracle Solaris x86 and Linux)
Install Oracle Solaris 10 Over a Network (Oracle SPARC)
Administering Driver Parameters and Jumbo Frames
Driver Parameters (Oracle Solaris OS)
Set Driver Parameters (Oracle Solaris OS)
Configuring Jumbo Frames (Oracle Solaris OS)
Change the MTU Temporarily (Oracle Solaris 10)
Change the MTU Temporarily (Oracle Solaris 11)
Configure Jumbo Frames (Linux)
Configure Link Aggregations (Oracle Solaris 10)
Display Information About Link Aggregations (Oracle Solaris 10)
Delete Link Aggregations (Oracle Solaris 10)
Configure Static VLANs (Oracle Solaris 10)
Analyze Why the Device Link Is Missing
Before You Begin
Refer to the server's Administration Guide for instructions on how to display the ok prompt.
ok show-nets a) /pci@500/pci@0/pci@8/network@0,1 b) /pci@500/pci@0/pci@8/network@0 c) /pci@400/pci@0/pci@2/network@0,1 d) /pci@400/pci@0/pci@2/network@0 q) NO SELECTION Enter Selection, q to quit: q
Note - Checking the .properties output for each device is the surest way to identify the device.
The following examples assume that /pci@400/pci@0/pci@2/network@0,1 is a port on the EM.
ok cd /pci@400/pci@0/pci@2/network@0,1
ok .properties
The output will be similar to the following:
ok .properties assigned-addresses 82060010 00000000 10000000 00000000 00100000 81050018 00000000 00001000 00000000 00000020 8206001c 00000000 10100000 00000000 00004000 82060030 00000000 10180000 00000000 00080000 local-mac-address a0 36 9f 01 b3 dc version Sun Quad Port GbE PCIe 2.0 ExpressModule, UTP FCode 3.11 2/16/12 phy-type mif reg 00060000 00000000 00000000 00000000 00000000 02060010 00000000 00000000 00000000 00100000 0206001c 00000000 00000000 00000000 00004000 02060030 00000000 00000000 00000000 00080000 board-model 7014759 model SUNW,pcie-igb compatible pciex8086,1521.108e.7b16.1 pciex8086,1521.108e.7b16 pciex8086,1521.1 pciex8086,1521 pciexclass,020000 pciexclass,0200 address-bits 00000030 max-frame-size 00002400 network-interface-type ethernet device_type network name network fcode-rom-offset 00000000 interrupts 00000001 cache-line-size 00000010 class-code 00020000 subsystem-id 00007b16 subsystem-vendor-id 0000108e revision-id 00000001 device-id 00001521 vendor-id 00008086
If you do not see the EM device listed, check that the EM is properly seated. If necessary, reinstall the EM.
ok device-end
