Go to main content
Sun Flash Accelerator F40 PCIe Card Product Notes
Exit Print View
Updated: March 2017
Downloading the Card Software Package
To find the card software package that includes the DDCLI utility, access My Oracle Support and download the latest software package for the Sun Flash Accelerator F40 PCIe Card.
  1. Sign in to MyOracle Support at https://support.oracle.com.
  2. Click the "Patches & Updates" tab.
  3. In the "Patch Search" box on the right side, select "Product or Family (Advanced Search)"
  4. Enter a partial product name for "Product is".
    A list of matches displays.
  5. Select the product of interest.
    Select one or more "releases" in the "Release is" drop down list.
    Close the pop-up window.
  6. Click Search.
    A list of product downloads (listed as patches) displays.
  7. Select the download of interest.
    The Download Information Page displays.
    If, on the Download Information Page, you get the message "You do not have permissions to download this Patch...", see How Patches and Updates Entitlement Works at https://support.oracle.com to help you determine the reason.
