man pages section 7: Device and Network Interfaces
Exit Print View
Updated: July 2014
audio810(7D)
Name
audio810 - Intel ICH series, nVidia nForce series and AMD 8111 audio core support
Description
The audio810 driver provides support for AC 97 audio controllers embedded in Intel ICH, nVidia nForce, and AMD 8111 chips.
Files
/kernel/drv/audio810
32-bit kernel driver module
/kernel/drv/amd64/audio810
64-bit x86 kernel driver module
/kernel/drv/audio810.conf
audio810 driver configuration file
Attributes
See attributes(5) for a descriptions of the following attributes:
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Architecture
PC-based systems
Availability
driver/audio/audio810
Interface Stability
Uncommitted
See also
ioctl(2), attributes(5), audio(7I), mixer(7I), streamio(7I)
AMD-8111 HyperTransport I/O Hub Data Sheet — Advanced Micro Devices Inc.
ALC655 Specification — Realtek Inc.
Notes
Some laptops (including Sony VAIO, among others), have their on-board amplifier powered down by default, meaning that audio is suppressed even if hardware and the audio810 driver are working normally. To correct this, set the ac97-invert-amp=1 property in the /kernel/drv/audio810.conf to power-up the amplifier.
