man pages section 7: Device and Network Interfaces
Exit Print View
Updated: July 2014
bfe(7D)
Name
bfe - Device driver for Broadcom BCM4401 100Base-T NIC
Description
The bfe Fast Ethernet driver is GLD-based and supports the Broadcom BCM4401 100Base-T NIC adapters :pci14e4,170c Broadcom BCM4401 100Base-T..
The bfe driver supports IEEE 802.3 auto-negotiation, flow control and VLAN tagging.
Configuration
The default configuration is auto-negotiation with bidirectional flow control. The advertised capabilities for auto-negotiation are based on the capabilities of the PHY.
You can set the capabilities advertised by the bfe controlled device using dladm(1M). The driver supports only those parameters which begin with en (enabled) in the parameters listed by the command dladm(1M). Each of these boolean parameters determines if the device advertises that mode of operation when the hardware supports it.
Files
/dev/bfe
Special character device
/kernel/drv/amd64/bfe
64-bit device driver (x86)
Attributes
See attributes(5) for a description of the following attributes:
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Architecture
SPARC, x86
See also
dladm(1M), netstat(1M) , driver.conf(4), attributes (5), ieee802.3(5), dlpi(7P), streamio(7I)
Writing Device Drivers for Oracle Solaris 11.2
STREAMS Programmer's Guide
Oracle Solaris 11.2 Programming Interfaces Guide
IEEE 802.3ae Specification - 2002
