Go to main content
Oracle® ILOM Feature Updates and Release Notes Firmware Release 3.2.x
Exit Print View
Updated: April 2018
Download Product Software and Firmware
  1. Go to http://support.oracle.com.
  2. Sign in to My Oracle Support.
  3. At the top of the page, click the Patches & Updates tab.
  4. In the Patch Search panel, click Product or Family (Advanced).
  5. In the Product Is list box, type a full or partial product name until a list of product matches appears in the list box, and then select the product name of interest.
    Example Product Names: Oracle Server X5-2 or SPARC M6-32.
  6. In the Release Is list box:
    1. Click the Down arrow in the Release Is list box to display a list of matching product folders.
      A list of one or more product software releases appears.
    2. Select the check box next to the software release of interest.
      For example: X4-2 SW 1.0.1 or SPARC M6-32 Sun Systems Firmware 9.2
  7. Click Search.
    A Patch Search Results screen appears displaying a list of patch names and descriptions.
  8. In the Patch Search Results screen, select the Patch Name of interest.
  9. In the Patch Name selection, click one of the following actions:
    • Readme – Opens the selected patch Readme file.
    • Add to Plan – Adds the selected patch to a new or existing plan.
    • Download – Downloads the selected patch.
Related Information
