Go to main content
Oracle® ILOM Feature Updates and Release Notes Firmware Release 3.2.x
Exit Print View
Updated: April 2018
Internet Explorer (IE) 9 - Exhibiting Slow Response Time or Time-Out Behavior
Issue: Experienced one or more of the following behaviors with the IE 9 browser: 1) Unable to establish a web connection to Oracle ILOM after logging in and providing a password; 2) Experienced a long delay after clicking on a tab in Oracle ILOM; 3) Received a browser timeout error message.
Workaround: Follow these steps to edit the system registry by adding an internet setting for background connections.
  1. Open the Registry Editor (regedit.exe).
    For example, click Start, click Run, type regedit, and click OK.
  2. Navigate to the following registry key:
    HKEY_CURRENT_CONFIG > Software > Microsoft > Windows > Current Version> Internet Settings
  3. In the Edit menu, point to New, and then click DWORD Value.
  4. Type BackgroundConnections and press Enter.
  5. Perform the following to set a value for the new BackgroundConnection entry:
    1. Select the BackgroundConnections entry.
    2. Click Edit > Modify;
    3. Set value to 0
    4. Click OK
  6. Confirm that new registry entry for DWORD was created with a value of 0.
  7. Restart Internet Explorer.
