Skip Navigation Links
Exit Print View
Sun Ethernet Fabric Operating System
RIP Administration Guide
search filter icon
search icon
Document Information
Using This Documentation
Product Notes
Related Documentation
Acronyms and Abbreviations
CLI Command Modes
Feedback
Support and Accessibility
RIP Overview
Protocol Description
Configuring the RIP Topology Example
RIP Topology 1
RIP Topology 2
Configure Switch 1
Configure Switch 2
Configure Switch 3
General Configurations
Managing RIP
Enable RIP
Disable RIP
Enabling RIP on an IP Network
Configuring RIP Security
Enable RIP Security
Disable RIP Security
Configuring the RIP Packet Retransmission Interval and Retry Count
Set the RIP Packet Retransmission Interval and Retry Count
Reset the Retransmission Interval and Retry Count
Configuring RIP Neighbors
Add a RIP Neighbor
Remove a RIP Neighbor
Configuring the RIP Passive Interface
Enable the RIP Passive Interface
Disable the RIP Passive Interface
Configuring the Output Delay
Enable the Output Delay
Disable the Output Delay
Configuring Redistribution
Enable Redistribution
Test Redistribution
Disable Redistribution
Configuring the Default Metric
Set the Default Metric
Test the Default Metric
Reset the Default Metric
Managing the auto-summary Option
Disable the auto-summary Option
Enable the auto-summary Option
Configuring Interface-Specific RIP Parameters
Configuring Interface-Specific Authentication
Enable Interface-Specific Authentication
Enable Authentication on Both Switches
Disable Interface-Specific Authentication
Configuring the RIP Default Route Propagation
Set the Default Route Propagation
Install the Default Route
Test the Default Route Origination and Installation
Disable the Default Route
Configuring the Version for Receiving RIP Advertisement
Set the Version
Reset the Version
Configuring the Summary Address
Set the Summary Address
Test the Summary Address Configuration
Configure Basic Timers
Configuring the split-horizon Option
Configure the split-horizon Option
Enable the split-horizon Option With Poison Reverse
Disable the split-horizon Option
Configuring the Debug Level for RIP
Enable Debug
Disable Debug
  1. On switch 1, enter the configuration mode for the interface.
    SEFOS# configure terminal
    SEFOS(config)# interface vlan 1
    SEFOS(config-if)# exit
  2. Enter the configuration mode for the router.
    SEFOS(config)# router rip
    SEFOS(config-router)# network 10.0.0.1
    SEFOS(config-router)# exit
  3. Enter the configuration mode for VLAN 1.
  4. Enable the split-horizon option.
    SEFOS(config-if)# ip split-horizon
  5. Review the configuration information.
    SEFOS# show ip protocols
    Routing Protocol is rip
    Vrf  default
     RIP2 security level is Maximum
     Redistributing : rip, bgp, connected, ospf, static
     Output Delay is disabled
     Retransmission timeout interval is 5 seconds
     Number of retransmission retries is 36
     Default metric is 3
     Auto-Summarisation of routes is disabled
     Routing for Networks :
       10.0.0.0
     Routing Information Sources :
     Interface Specific Address Summarization :
       40.0.0.0/8    for vlan1
     Trusted Neighors :
     Interface vlan1
      Sending updates every 60 seconds
      Invalid after 120 seconds
      Flushed after 120 seconds
      Send version is 1 2, receive version is 1 2
      Authentication type is none
      Split Horizon is enabled
      Installs default route received
      Restricts default route origination
