Skip Navigation Links
Exit Print View
Sun Ethernet Fabric Operating System
LA Administration Guide
search filter icon
search icon
Document Information
Using This Documentation
Product Notes
Related Documentation
Acronyms and Abbreviations
CLI Command Modes
Feedback
Support and Accessibility
LA Overview
Protocol Description
Configuring LA
LA Topology Example
Configuration Guidelines
Default Settings
Enable Link Aggregation
Configuring Port-Channel Interfaces
Configure Port-Channel Interfaces
Configure the LACP Port Priority
Configure the LACP System Priority
Configure Port Channel Load Balancing
Configure the LACP System Identifier
Configure the LACP Port Identifier
Setting the MTU Value
Set the MTU Value on one or More Ports
Set the MTU Value of the Port Channel
Configure the LACP Wait Time
Configure the LACP Time-Out Value
Display the LACP Status
Interaction Between LA and VLANs
You can set the MTU value for an individual port or a set of ports by using the procedure in this section. In the following procedure, ports 0/1, 0/2, and 0/3 are part of the LA. When the MTU of a port in a bundle is different than the MTU for the port channel, the port will not be brought up in the bundle. See LA Topology Example for the topology referenced in this procedure.
  1. Review the port state behavior with the default MTU settings for all of the ports.
    SEFOS# show interface mtu
    Ex0/1   MTU size is 1500
    Ex0/2   MTU size is 1500
    Ex0/3   MTU size is 1500
    Ex0/4   MTU size is 1500
    Ex0/5   MTU size is 1500
    Ex0/6   MTU size is 1500
    Ex0/7   MTU size is 1500
    Ex0/8   MTU size is 1500
    Ex0/9   MTU size is 1500
    Ex0/10  MTU size is 1500
    Ex0/11  MTU size is 1500
    Ex0/12  MTU size is 1500
    Ex0/13  MTU size is 1500
    Ex0/14  MTU size is 1500
    Ex0/15  MTU size is 1500
    Ex0/16  MTU size is 1500
    Ex0/17  MTU size is 1500
    Ex0/18  MTU size is 1500
    Ex0/19  MTU size is 1500
    Ex0/20  MTU size is 1500
    Ex0/21  MTU size is 1500
    Ex0/22  MTU size is 1500
    Ex0/23  MTU size is 1500
    Ex0/24  MTU size is 1500
    po1     MTU size is 1500
    vlan1   MTU size is 1500
  2. Create the interface (0/1 in this example).
    SEFOS# configure terminal
    SEFOS(config)# interface extreme-ethernet 0/1
    SEFOS(config-if)# shutdown
  3. Configure the MTU.
    SEFOS(config-if)# mtu 1000
    SEFOS(config-if)# no shutdown
    SEFOS(config-if)# end
  4. Review the etherchannel information.
    The output has been truncated for readability.
    SEFOS# show etherchannel detail
                     Ports in the Group
    Port : Ex0/1
    Port State = Down, Not in Bundle
    Channel Group : 1
    Mode : Active
    Note - After you configure the MTU value on port 0/1 to 1000, note that because the MTU value on port 0/1 is different than the MTU value of the port channel interface, the extreme-ethernet port, 0/1, in switch A will be brought down and out of the bundle.
