Skip Navigation Links
Exit Print View
Sun Ethernet Fabric Operating System
PVRST+ Administration Guide
search filter icon
search icon
Document Information
Using This Documentation
Product Notes
Related Documentation
Acronyms and Abbreviations
CLI Command Modes
Feedback
Support and Accessibility
PVRST+ Overview
Protocol Description
Topology Example
Default Settings
Rapid STP
Bridge ID and Switch Priority
Election of the Root Switch
Port States
Port Roles
Rapid Convergence
Proposal Agreement Sequence
Topology Change and Topology Change Detection
VLAN Module
Configuring RSTP in PVRST+
Enable IPv6 Support and Assign IPv6 Addresses
Configure the Spanning-Tree Path Cost
Configure the Spanning Tree Link Type
Configure the Spanning-Tree portfast Setting
Configure Spanning Tree Timers
Display the Spanning Tree Status
Configure the Transmit Hold Count
Configure Encapsulation
Configure the BPDU Guard
Configure the Root Guard
Configuring the VLAN Module
Disable GVRP
Configuring Trunk and Access Ports
Configure a Trunk Port
Configure an Access Port
Set Up PVID on a Port
Configure VLANS and Display the PVRST+ Information for VLANs
To make the PVRST+ module completely operational, you must configure the VLAN module. Before you configure VLAN as described in these sections, see VLAN Module to ensure that the configuration guidelines are satisfied.
The examples in this section use switch B (hostname TOR-1), port 0/1, and VLAN 10 and VLAN 20.
