Skip Navigation Links
Exit Print View
Sun Ethernet Fabric Operating System
IEEE DCBX Administration Guide
search filter icon
search icon
Document Information
Using This Documentation
Product Notes
Related Documentation
Acronyms and Abbreviations
CLI Command Modes
Feedback
Support and Accessibility
DCB Overview
DCB Protocol
ETS Feature
PFC Feature
Application Priority Feature
Configuring DCB
DCB Example Topology
Configuration Specifications
Configuration Guidelines
Default Settings
Configure DCB Features
Verifying DCB and LLDP Configurations
Determine Whether Interfaces Are Active
Determine Whether LLDP is Running and Recognizing Peers
Enable DCB
Disable DCB
Enable DCB for Each Interface
Disable DCB for Each Interface
Enable and Disable a Specific DCB Feature
Configure the Mode for the DCB Feature
Configure DCB ETS Attributes
Configure DCB PFC Attributes
Configure DCB APP features
Configure LLDP DCBX TLVs
Show DCBX Feature Statistics and Control Information
Display Output of Unstarted DCBX Protocol Exchange
Clear Feature Statistics
Display Output Showing a Down Link
You can set PFC feature attributes. But whether your configuration takes effect depends on the willing state on both local and remote side.
When local willing state is false, the new configuration changes the operational status, but changes the remote configuration only if the remote willing state is true.
  1. View the original configuration before any change is made.
    SEFOS# show interfaces extreme-ethernet 0/21 dcb priority-flow-control detail
    Port             :      Ex0/21
    Show Type        :      Admin Config
    Feature          :      Priority Flow Control
    Enable           :      true
    Advertise        :      true
    Willing          :      false
    Priority Mask    :     0      0      0      0      1      0      0      0
    Max Traffic Class:      8
    Show Type        :      Oper Config
    Errors           :      0x0 - none
    Operational Mode :      true
    Syncd with Peer  :      false
    Show Type        :      Peer Config
    Local Interface  :      Ex0/21
    Status           :      successful
    Enable           :      true
    Willing          :      true
    Total Entries Displayed : 1
    The local willing state is false and the remote willing state is true, so local configuration change are used on both the local switch and the remote Oracle Solaris server.
  2. Configure ETS with different bandwidth alocation.
    SEFOS# configure terminal
    SEFOS(config)# interface extreme-ethernet 0/21
    SEFOS(config-if)# set dcb priority-flow-control vlan-priority 0 0 1 1 0 0 0 0
    SEFOS(config-if)# end
  3. View the configuration to verify that configuration changes have been applied to both the local and remote systems.
    Port             :      Ex0/21
    Enable           :      true
    Advertise        :      true
    Willing          :      false
    Priority Mask    :     0      0      1      1      0      0      0      0
    Errors           :      0x0 - none
    Syncd with Peer  :      true
    Status           :      successful
    Enable           :      true
    Willing          :      true
    The PFC configuration on the remote server is the same as the local configuration and is synchronized up with the switch.
  4. Change the willing state so that both local and remote willing states are true.
    SEFOS(config-if)# set dcb priority-flow-control willing enable
  5. Check output on the switch again to verify.
    Port             :      Ex0/21
    Enable           :      true
    Advertise        :      true
    Willing          :      true
    Errors           :      0x0 - none
    Status           :      successful
    Enable           :      true
    Willing          :      true
  6. Change the configuration again on the switch.
    The operational and remote configuration is not affected.
    SEFOS(config)# interfaces extreme-ethernet 0/21
    SEFOS(config-if)# set dcb priority-flow-control vlan-priority 0 0 1 0 0 0 0 0
    Port             :      Ex0/21
    Enable           :      true
    Advertise        :      true
    Willing          :      true
    Priority Mask    :     0      0      1      0      0      0      0      0
    Errors           :      0x0 - none
    Status           :      successful
    Enable           :      true
    Willing          :      true
    When both sides are willing to accept the changes, configuration on the interface with smaller MAC address is used. Port 21 of the switch has the MAC address 00:10:e0:2c:0f:41 and net 3 of the Oracle Solaris server has the MAC address 00:1b:21:bc:b4:89. The preceding output shows that the configuration of the switch is used.
  7. Change the willing state so that local willing is true and remote willing is false.
    Since the local willing state has already been set to true, type the following Oracle Solaris commands to change the remote willing state to false.
    # lldpadm set-atp -p willing=off -a net3 pfc
    # lldpadm show-atp -a net3 pfc
    AGENT       TLVNAME PROPERTY   PERM VALUE         DEFAULT       POSSIBLE
    net3         pfc     willing     rw   off            on             on,off
  8. Check output on the switch again to verify.
    Port             :      Ex0/21
    Enable           :      true
    Advertise        :      true
    Willing          :      true
    Errors           :      0x0 - none
    Priority Mask    :     0      0      0      1      1      0      0      0
    Status           :      successful
    Enable           :      true
    Willing          :      false
    The local operational status has been changed to the remote configuration once the willing state is changed.
  9. Change the configuration again on the switch.
    Port             :      Ex0/21
    Enable           :      true
    Advertise        :      true
    Willing          :      true
    Errors           :      0x0 - none
    Status           :      successful
    Enable           :      true
    Willing          :      false
  10. Show the configuration details.
    When the local willing and remote willing states are both false, the local admin configuration should match the peer's configuration, since neither side is willing to accept the peer's configuration.
    Port             :      Ex0/21
    Enable           :      true
    Advertise        :      true
    Willing          :      false
    Priority Mask    :     0      0      0      1      0      0      0      0
    Errors           :      0x0 - none
    Status           :      successful
    Enable           :      true
    Willing          :      false
