Oracle® Solaris Cluster 4.2 Hardware Administration Manual
Exit Print View
Updated: July 2014, E39726–01
Using the Terminal Concentrator
This section describes the procedures about how to use the terminal concentrator in a cluster.
Table 2-1  Task Map: Using the Terminal Concentrator
Task
Instructions
Connect to a node's console through the terminal concentrator
Reset a terminal concentrator port
