Go to main content
Oracle® Server X5-2 Installation Guide
Exit Print View
Updated: January 2021
Attach Tool-less Slide-Rail Assemblies
Use this procedure to attach tool-less slide-rail assemblies to the rack.
  1. Orient the slide-rail assembly so that the ball-bearing track is forward and locked in place.
    image:Figure showing the slide-rail being oriented with the ball-bearing                             track locked into place.
    Number
    Description
    1
    Slide-rail
    2
    Ball-bearing track
    3
    Locking mechanism
  2. Starting with either the left or right side of the rack, align the rear of the slide-rail assembly against the inside of the rear rack rail, and push until the assembly locks into place with an audible click.
    image:Figure showing the Slide-rail assembly being aligned with the                             rack.
  3. Align the front of the slide-rail assembly against the outside of the front rack rail, and push until the assembly locks into place with an audible click.
  4. Repeat Step 1 through Step 3 to attach the slide-rail assembly to the other side of the rack.
Related Information
