Skip Navigation Links | |
Exit Print View | |
Sun Storage Common Array Manager Software Release Notes, Release 6.10 Update for Solaris OS Hosts |
1. CAM 6.10 Update Release Notes for Solaris OS
What You Get With the Software
Mixing Drive Speeds and Capacities
Supported Host Operating Systems
Best Practices for Browser Performance
2500 Array Support for VMware ESX 4.1 with Firmware 07.35.55.10 and later
6540, 6140, and FLX380 Arrays Upgrade
Sun Storage F5100 Flash Array Notes
Controller Smart battery replacement procedure
Battery nears expiration: 06.xx write back cache should not be disabled
Both RAID controllers reboot after 828.5 days--2500/6000 arrays
Reboots occur due to ancient I/O being aborted in large configurations
Reregister Auto Service Request for CAM
Auto Service Request advisory note: DTS Listener transfer
Array name remains unchanged after a full array reset
Access Configuration: Cascaded J4400 issues
Access Configuration fails with error: java.util.HashMap cannot be cast to java.util.Properties
Access Configuration: non-zoned SAS2 wide port aggregation FRU Report display—F5100 + 6Gb/sec HBA
Array lock key must be set before configuration files are imported
ComponentInsertEvent not generated for disk drive inserted into J4200
Current Jobs page can take more than five minutes to display
Expander firmware 5.3.73 does not persist a SAS zone group
Replication status incorrect when primary volume fails
Service Advisor: replacing failed SIM with dual path configurations
Volumes not deleting from the Single Page window
Attempt to delete partner replication set on secondary array fails
Incorrect Windows server OS listed in CAM 6.9 Release Notes
Incorrect sscs add notification description in CLI guide
2500 Series Release Notes: Simplex vs. Duplex Configurations
Disk Locked description is inaccurate in online help
Firmware upgrade fails with error: FWR_UPGRADE_FAILURE,6 for J4200/J4400 arrays
Firmware upgrade fails on J4400 SATA drives
Firmware upgrade fails when expander and disks are upgraded together
Firmware upgrade not recognized by GUI until agent runs
Sun Blade 6000 firmware upgrade fails with down-level expander
Sun Blade 6250 and 6270—upgrading network expansion modules fails
Installation and Upgrade Issues
Error occurs when upgrading 2510 controller and drive firmware
Installation fails on SUSE 10.3 32-bit and 64-bit hosts
Solaris with Veritas DMP or other host type
Error—”no execute access to opt/SMgr/agent/ notifysmagent.sh”—occurs during system boot-up
UTM LUNs Controlled by “Solaris Traffic Manager” 6000/2500 arrays
The Sun Storage Common Array Manager (CAM) 6.10 Update release is available only for Solaris OS management hosts.
Oracle's Sun Storage Common Array Manager (CAM) 6.10 software that includes the fix for the following CVEs is supported only on Oracle Solaris 10 SPARC and x86 platforms. If you are running the CAM software on Windows or Linux, you will need to migrate to Oracle Solaris 10 to use the fix.
CVE-2007-5333,CVE-2007-5342,CVE-2007-6286,CVE-2008-0002,CVE-2008-1232,CVE-2008-1947,CVE-2008-2370,CVE-2008-2938,CVE-2008-5515,CVE-2009-0033,CVE-2009-0580,CVE-2009-0781,CVE-2009-0783,CVE-2009-2693,CVE-2009-2901,CVE-2009-2902,CVE-2009-3548,CVE-2010-1157,CVE-2010-2227,CVE-2010-3718,CVE-2010-4172,CVE-2010-4312,CVE-2011-0013,CVE-2011-0534,CVE-2011-1184,CVE-2011-2204,CVE-2011-2526,CVE-2011-3190.
If you cannot migrate from Windows or Linux to Oracle Solaris 10 for installing CAM 6.10 with the CVE fix, you can continue to use CAM 6.9 on Windows or Linux. In this case, in order to address the CVE issues, you need to stop the Web Console on Windows or Linux by performing one of the following steps:
For Windows: C:\Sun\WebConsole\bin\smcwebserver stop
For Linux: /opt/sun/webconsole/bin/smcwebserver stop
This CAM 6.10 release note contains important information about:
Controller and disk firmware updates for 2530-M2, 2540-M2, 2510, 2530, 2540, 6180, and 6580/6780 arrays
Bug fixes that correct previous known software problems
Controller and disk firmware has been updated with this release. See the Sun Storage Common Array Manager Baseline Firmware Reference, Version 6.10 Update for more information.
