Skip Navigation Links | |
Exit Print View | |
Sun Storage Common Array Manager Software Release Notes, Release 6.10 Update for Solaris OS Hosts |
1. CAM 6.10 Update Release Notes for Solaris OS
Controller and Disk Firmware Updates
What You Get With the Software
Mixing Drive Speeds and Capacities
Supported Host Operating Systems
Best Practices for Browser Performance
2500 Array Support for VMware ESX 4.1 with Firmware 07.35.55.10 and later
6540, 6140, and FLX380 Arrays Upgrade
Sun Storage F5100 Flash Array Notes
Controller Smart battery replacement procedure
Battery nears expiration: 06.xx write back cache should not be disabled
Both RAID controllers reboot after 828.5 days--2500/6000 arrays
Reboots occur due to ancient I/O being aborted in large configurations
Reregister Auto Service Request for CAM
Auto Service Request advisory note: DTS Listener transfer
Array name remains unchanged after a full array reset
Access Configuration: Cascaded J4400 issues
Access Configuration fails with error: java.util.HashMap cannot be cast to java.util.Properties
Access Configuration: non-zoned SAS2 wide port aggregation FRU Report display—F5100 + 6Gb/sec HBA
Array lock key must be set before configuration files are imported
ComponentInsertEvent not generated for disk drive inserted into J4200
Current Jobs page can take more than five minutes to display
Expander firmware 5.3.73 does not persist a SAS zone group
Replication status incorrect when primary volume fails
Service Advisor: replacing failed SIM with dual path configurations
Volumes not deleting from the Single Page window
Attempt to delete partner replication set on secondary array fails
Incorrect Windows server OS listed in CAM 6.9 Release Notes
Incorrect sscs add notification description in CLI guide
2500 Series Release Notes: Simplex vs. Duplex Configurations
Disk Locked description is inaccurate in online help
Firmware upgrade fails with error: FWR_UPGRADE_FAILURE,6 for J4200/J4400 arrays
Firmware upgrade fails on J4400 SATA drives
Firmware upgrade fails when expander and disks are upgraded together
Firmware upgrade not recognized by GUI until agent runs
Sun Blade 6000 firmware upgrade fails with down-level expander
Sun Blade 6250 and 6270—upgrading network expansion modules fails
Installation and Upgrade Issues
Error occurs when upgrading 2510 controller and drive firmware
Installation fails on SUSE 10.3 32-bit and 64-bit hosts
Solaris with Veritas DMP or other host type
Error—”no execute access to opt/SMgr/agent/ notifysmagent.sh”—occurs during system boot-up
UTM LUNs Controlled by “Solaris Traffic Manager” 6000/2500 arrays
Following is a list of the notable bug fixes delivered with the CAM 6.10 Update.
Bug 20470433 - CAM Email not presenting 'From' field in email alerts.
Bug 19778233 - CAM removes drive serial number substrings and prevents firmware upgradeBug 19563133 - Firmware upgrade fails on a 6780 using CAM 6.10 going from 7.80 to 7.84Bug 19451239 - Drives not listed in Service AdviserBug 19447926 - In-Band management registration succeeds but then array is not accessibleBug 19009546 - Upgrade embedded apache tomcat to 6.0.43 for security issues.Bug 18756656 - Upgrade JDK used by CAM processes to Java 6 update 95.Bug 18186833 - Upgrade JDK used by CAM installer/uninstaller to Java 6 update 95.Bug 20488443 - 6x80: Require NetApp Fix
