Skip Navigation Links | |
Exit Print View | |
Sun Storage Common Array Manager Software Release Notes, Release 6.10 Update for Solaris OS Hosts |
1. CAM 6.10 Update Release Notes for Solaris OS
Controller and Disk Firmware Updates
Mixing Drive Speeds and Capacities
Supported Host Operating Systems
Best Practices for Browser Performance
2500 Array Support for VMware ESX 4.1 with Firmware 07.35.55.10 and later
6540, 6140, and FLX380 Arrays Upgrade
Sun Storage F5100 Flash Array Notes
Controller Smart battery replacement procedure
Battery nears expiration: 06.xx write back cache should not be disabled
Both RAID controllers reboot after 828.5 days--2500/6000 arrays
Reboots occur due to ancient I/O being aborted in large configurations
Reregister Auto Service Request for CAM
Auto Service Request advisory note: DTS Listener transfer
Array name remains unchanged after a full array reset
Access Configuration: Cascaded J4400 issues
Access Configuration fails with error: java.util.HashMap cannot be cast to java.util.Properties
Access Configuration: non-zoned SAS2 wide port aggregation FRU Report display—F5100 + 6Gb/sec HBA
Array lock key must be set before configuration files are imported
ComponentInsertEvent not generated for disk drive inserted into J4200
Current Jobs page can take more than five minutes to display
Expander firmware 5.3.73 does not persist a SAS zone group
Replication status incorrect when primary volume fails
Service Advisor: replacing failed SIM with dual path configurations
Volumes not deleting from the Single Page window
Attempt to delete partner replication set on secondary array fails
Incorrect Windows server OS listed in CAM 6.9 Release Notes
Incorrect sscs add notification description in CLI guide
2500 Series Release Notes: Simplex vs. Duplex Configurations
Disk Locked description is inaccurate in online help
Firmware upgrade fails with error: FWR_UPGRADE_FAILURE,6 for J4200/J4400 arrays
Firmware upgrade fails on J4400 SATA drives
Firmware upgrade fails when expander and disks are upgraded together
Firmware upgrade not recognized by GUI until agent runs
Sun Blade 6000 firmware upgrade fails with down-level expander
Sun Blade 6250 and 6270—upgrading network expansion modules fails
Installation and Upgrade Issues
Error occurs when upgrading 2510 controller and drive firmware
Installation fails on SUSE 10.3 32-bit and 64-bit hosts
Solaris with Veritas DMP or other host type
Error—”no execute access to opt/SMgr/agent/ notifysmagent.sh”—occurs during system boot-up
UTM LUNs Controlled by “Solaris Traffic Manager” 6000/2500 arrays
The CAM 6.10 software is available for download from the following locations:
To download from Oracle Software Delivery Cloud:
Go to https://edelivery.oracle.com/and sign in.
From Select a Product Pack, select Sun Products.
From Platform, select the OS version for your host.
Select Sun Storage Common Array Manager Software 6.10, and download the software.
For detailed MOS download steps, see the knowledge article “How to Download Common Array Manager (CAM) Software and Patches” Doc ID 1296274.1 available on MOS.
Note - Each array should be managed by one CAM management host only. Installing the management software on more than one host to manage the same array can cause discrepancies in the information reported by CAM.
Sun Storage Common Array Manager Contents lists the version information for the software included in this release.
Table 1-1 Sun Storage Common Array Manager Contents
The CAM 6.10 documentation set is located at:
http://docs.oracle.com/cd/E51876-01/index.html
The documentation set consists of the 6.9.x titles which apply to CAM 6.10, as noted in Where to Find CAM 6.10 and Disk Array Information.
Table 1-2 Where to Find CAM 6.10 and Disk Array Information
Visit https://support.oracle.com/CSP/main/article?cmd=show&type=NOT&doctype=HOWTO&id=1296274.1 to get details about array firmware, and find out more about downloading Common Array Manager software and its patches.
Join or start a discussion with Oracle experts and industry peers in the My Oracle Support Community for Storage Disk 6000 and 2000 Series RAID Arrays at: https://community.oracle.com/community/support/oracle_sun_technologies/disk_storage_2000__3000__6000_raid_arrays_&_jbods
