Attach Tool-less Slide-Rail Assemblies
Use this procedure to attach
tool-less slide-rail assemblies to the rack.
Note -
Right-angle AC power cables (part number 7079727 - Pwrcord, Jmpr, Bulk, SR2,
2m, C14RA, 10A, C13) must be installed before slide-rails when installing the
Oracle Server X6-2 into a Sun Rack II 1042 (1000-mm) system rack. The standard rail
kit tool-less slide-rails impede access to the 15kVA and 22kVA Power
Distribution Unit (PDU) electrical sockets in the 1000-mm rack. If you use the
standard AC power cables and then install the slide-rails into the rack, you
will be unable to disconnect or remove the AC power cables. Once the slide-rails
have been installed into the rack, you will be unable to disconnect or remove
Orient the slide-rail assembly so that the ball-bearing track is forward and locked in
place.
1
Slide-rail
2
Ball-bearing track
3
Locking mechanism
Starting with either the left or right side of the rack, align the rear of the slide-rail
assembly against the inside of the rear rack rail, and push until the assembly locks into place with
an audible click.
Align the front of the slide-rail assembly against the outside of the front rack rail, and
push until the assembly locks into place with an audible click.
Repeat Step 1 through
Step 3 to attach the slide-rail
assembly to the other side of the rack.
