Rackmount Kit Contents
The rackmount kit contains two slide-rails, two mounting brackets, and optional securing
screws.
Note -
Refer to the rackmount kit installation card for instructions on how to install
your server into a four-post rack using the slide-rail and cable management arm
options.
1
Slide-rails
2
Mounting brackets
3
Four M4 x 5 fine-pitch mounting bracket securing screws
(optional)
4
Installation card
