Table 25-2 General Settings
Setting | Description |
Show login information |
Select this option to show login information at the top of the screen on the home page. |
Allow password change |
Select this option to enable users to change their password. Do not enable this feature because passwords are synced from Reporting and Analytics. |
Use Suggested Qty (master switch) |
Select this option to enable the use of Suggesting Quantity Ordering (PAR or Forecasted). |
Use Visibility Criteria |
Select this option to enable the ability to use visibility criteria. |
Disable Cost Center Number in Search |
Select this option to enable searching cost center names only with Autocomplete enabled. |
Enable Sales Depletion by Order Type |
Select this option to enable sales depletion by recipe assignment per order type and price level. |
Enable Audit Trail |
Select this option to enable the user to view change history for certain modules. |
Calculate Average Usage for All Items |
Select this option to enable the Scheduler jobs to calculate the average usage for all items. If turned off, the average usage is only calculated for items and item groups that are configured to use suggested ordering by net sales or average usage. |
Autocomplete |
Select this option to turn on auto-complete text search capabilities. |
Default Item Price Behavior |
Select the default setting for Item price behavior (used for vendor purchase items):
Printout Type |
Select the printout type: PDF or HTML. PDF is recommended. |
HTML printout rendering |
if HTML is selected as the printout type, this determines how the HTML printouts appear, either in multiple pages or single pages |
"Select/Deselect all" selection type |
There are 2 modes:
Number of Rows before Page Navigation |
Suggested quantity is 100. More than 1000 records can cause the application to run slowly. |
Localization |
If Russian localization is required, select Russian Requirements to enable legal information to be printed on reports. |
Enable ENVD (master switch) |
This option is used for Russian localization only. |
Default Language |
Select the default language the organization uses when users are added directly through Inventory Management (not recommended). |
Parent topic: Settings
