Table 25-7 Usage Settings
Setting | Description |
Hide Filters on module start |
Select this option to prevent the system from showing the available filters when first opening the page. |
Show Item Number in Search |
Select this option to show the item number in a search. |
Sorting |
Select the order in which the system sorts waste documents. |
POS Waste Check Waste Group |
Select the waste group to which the system applies POS waste checks. |
Parent topic: Settings
