Go to main content
Oracle® Developer Studio 12.6: Performance Library User's Guide
Exit Print View
Updated: July 2017
SuperLU Interface
SuperLU has two driver routines, simple and expert, that can be called to completely solve a general unsymmetric sparse system in a similar manner to the one-call interface in SPSOLVE. These and other SuperLU user-callable routines are available in single precision, double precision, complex and double complex data types. Single precision names of all external routines are listed in the following tables. Man pages (section 3P) are available for these routines. Also see the man page of SuperMatrix(3P) for a description of the sparse matrix data structure that is used in the application.
Table 5  SuperLU Computational Routines
Routine
Description
sgstrf
Computes factorization
sgssvx
Factorizes and solves (expert driver)
sgssv
Factorizes and solves (simple driver)
sgstrs
Computes triangular solve
sgsrfs
Improves computed solution; provides error bounds
slangs
Computes one-norm, Frobenius-norm, or infinity-norm
sgsequ
Computes row and column scalings
sgscon
Estimates reciprocal of condition number
slaqgs
Equilibrates a general sparse matrix
Table 6  SuperLU Utility Routines
Routine
Description
LUSolveTime
Returns time spent in solve stage
LUFactTime
Returns time spent in factorization stage
LUFactFlops
Returns number of floating point operations in factorization stage
LUSolveFlops
Returns number of floating point operations in solve stage
sQuerySpace
Returns information on the memory statistics
sp_ienv
Returns specified machine dependent parameter
sPrintPerf
Prints statistics collected by the computational routines
set_default_options
Sets parameters that control solver behavior to default options
StatInit
Allocates and initializes structure that stores performance statistics
StatFree
Frees structure that stores performance statistics
Destroy_Dense_Matrix
Deallocates a SuperMatrix in dense format
Destroy_SuperNode_Matrix
Deallocates a SuperMatrix in supernodal format
Destroy_CompCol_Matrix
Deallocates a SuperMatrix in compressed sparse column format
Destroy_CompCol_Permuted
Deallocates a SuperMatrix in permuted compressed sparse column format
Destroy_SuperMatrix_Store
Deallocates actual storage that stores matrix in a SuperMatrix
sCopy_CompCol_Matrix
Copies a SuperMatrix in compressed sparse column format
sCreate_CompCol_Matrix
Allocates a SuperMatrix in compressed sparse column format
sCreate_Dense_Matrix
Allocates a SuperMatrix in dense format
sCreate_CompRow_Matrix
Allocates a SuperMatrix in compressed sparse row format
sCreate_SuperNode_Matrix
Allocates a SuperMatrix in supernodal format
sp_preorder
Permutes columns of original sparse matrix
sp_sgemm
Multiplies a SuperMatrix by a dense matrix
Calling SuperLU from C
SuperLU routines are written in C. Therefore, column- and row-related indices must be zero-based. In the following example, double precision simple driver dgssv() is called to compute factors L and U and to solve for the solution matrix.
Example 6  SuperLU Simple Driver
#include <stdio.h>
#include <sunperf.h>
#define M 5
#define N 5
int main(int argc, char *argv[])
    SuperMatrix A, L, U, B1, B2;
    int      perm_r[M];  /* row permutations from partial pivoting */
    int      perm_c[N];  /* column permutation vector */
    int      info, i;
    superlu_options_t options;
    SuperLUStat_t stat;
    trans_t  trans = NOTRANS;
    printf("Example code calling SuperLU simple driver to factor a \n");
    printf("general unsymmetric matrix and solve two right-hand-side matrices\n");
   /* the matrix in Harwell-Boeing format. */
    int m = M;
    int n = M;
    int nnz = 12;
    double *dp;
   /* nonzeros of A, column-wise */
    double a[] = {1.0, 2.0, 3.0,  4.0, 5.0,  6.0,
                  7.0, 8.0, 9.0, 10.0, 11.0, 12.0};
   /* row index of nonzeros */
    int asub[] = {0, 1, 4, 1, 2, 4, 0, 2, 0, 3, 3, 4};
   /* column pointers */
    int xa[]   = {0, 3, 6, 8, 10, 12};
    /* Create Matrix A in the format expected by SuperLU */
    dCreate_CompCol_Matrix(&A, m, n, nnz, a, asub, xa, SLU_NC, SLU_D, SLU_GE);
    int nrhs = 1;
    double rhs1[] = {17.0, 6.0, 13.0, 21.0, 21.0};
    double rhs2[] = {17*.3, 6*.3, 13*.3, 21*.3, 21*.3};
    /* right-hand side matrix B1, B2 */
    dCreate_Dense_Matrix(&B1, m, nrhs, rhs1, m, SLU_DN, SLU_D, SLU_GE);
    dCreate_Dense_Matrix(&B2, m, nrhs, rhs2, m, SLU_DN, SLU_D, SLU_GE);
    /* set options that control behavior of solver to default parameters */
    set_default_options(&options);
    options.ColPerm = NATURAL;
    /* Initialize the statistics variables. */
    StatInit(&stat);
    /* factor input matrix and solve the first right-hand-side matrix */
    dgssv(&options, &A, perm_c, perm_r, &L, &U, &B1, &stat, &info);
    printf("\nsolution matrix B1:\n");
    dp = (double *) (((NCformat *)B1.Store)->nzval);
    printf("    i    rhs[i]     expected\n");
    for (i=0; i<M; i++)
      printf("%5d   %7.4lf     %7.4lf\n", i, dp[i], 1.0);
    printf("Factor time  = %8.2e sec\n", stat.utime[FACT]);
    printf("Solve time   = %8.2e sec\n\n\n", stat.utime[SOLVE]);
    /* solve the second right-hand-side matrix */
    dgstrs(trans, &L, &U, perm_c, perm_r, &B2, &stat, &info);
    printf("solution matrix B2:\n");
    dp = (double *) (((NCformat *)B2.Store)->nzval);
    for (i=0; i<M; i++)
      printf("%5d   %7.4lf     %7.4lf\n", i, dp[i], 0.3);
    printf("Solve time   = %8.2e sec\n", stat.utime[SOLVE]);
    StatFree(&stat);
    Destroy_CompCol_Matrix(&A);
    Destroy_SuperMatrix_Store(&B1);
    Destroy_SuperMatrix_Store(&B2);
    Destroy_SuperNode_Matrix(&L);
    Destroy_CompCol_Matrix(&U);
Running the above example:
my_system% cc -xmemalign=8s simple.c -library=sunperf
my_system% a.out
solution matrix B1:
    i    rhs[i]     expected
    0    1.0000      1.0000
    1    1.0000      1.0000
    2    1.0000      1.0000
    3    1.0000      1.0000
    4    1.0000      1.0000
Factor time  = 5.43e-02 sec
Solve time   = 6.76e-03 sec
solution matrix B2:
    i    rhs[i]     expected
    0    0.3000      0.3000
    1    0.3000      0.3000
    2    0.3000      0.3000
    3    0.3000      0.3000
    4    0.3000      0.3000
Example 7  SuperLU Expert Driver
#include <stdio.h>
#define M    5
#define N    5
#define NRHS 1
    SuperMatrix A, L, U, B, X;
    int      etree[N];   /* elimination tree */
    double   ferr[NRHS]; /* estimated forward error bound */
    double   berr[NRHS]; /* component-wise relative backward error */
    double   C[N], R[M]; /* column and row scale factors */
    double   rpg, rcond;
    char     equed[1];   /* Specifies the form of equilibration that was done */
    double   *work, *dp; /* user-supplied workspace */
    int      lwork = 0;  /* 0 for workspace to be allocated by system malloc */
    int      info, i;
    SuperLUStat_t stat;
    mem_usage_t    mem_usage;
    printf("Example code calling SuperLU expert driver\n\n");
    int m = M;
    int n = M;
    int nnz = 12;
    int nrhs = NRHS;
    double rhs[] = {17.0, 6.0, 13.0, 21.0, 21.0};
    /* right-hand-side matrix B */
    dCreate_Dense_Matrix(&B, m, nrhs, rhs, m, SLU_DN, SLU_D, SLU_GE);
    /*  solution matrix X */
    dCreate_Dense_Matrix(&X, m, nrhs, rhs, m, SLU_DN, SLU_D, SLU_GE);
    StatInit(&stat);
    dgssvx(&options, &A, perm_c, perm_r, etree, equed, R, C, &L, &U, work, lwork,
           &B, &X, &rpg, &rcond, ferr, berr, &mem_usage, &stat, &info);
    dp = (double *) (((NCformat *)X.Store)->nzval);
    for (i=0; i<M; i++)
             i, dp[i], 1.0);
    StatFree(&stat);
    Destroy_SuperMatrix_Store(&B);
my_system% cc -xmemalign=8s expert.c -library=sunperf
my_system% a.out
    i    rhs[i]     expected
    0    1.0000      1.0000
    1    1.0000      1.0000
    2    1.0000      1.0000
    3    1.0000      1.0000
    4    1.0000      1.0000
Factor time  = 1.25e-03 sec
Solve time   = 1.70e-04 sec
Calling SuperLU from Fortran
The simplest way to call SuperLU from Fortran is through the SPSOLVE interface. SuperLU can be selected to solve an unsymmetric coefficient matrix through input argument MTXTYP of routine DGSSIN(), which is the initialization routine in SPSOLVE. The same argument also exists in the one-call interface routine DGSSFS().
Valid options for MTXTYP are listed in the following table. To invoke SuperLU, select 's0' or 'S0' as matrix type. Since SPSOLVE is Fortran-based, all column and row indices associated with the input matrix should be one-based. However, if SuperLU is invoked through DGSSIN() or DGSSFS() (by setting MTXTYP = 's0' or 'S0'), these indices must be zero-based.
Table 7  Matrix Type Options for DGSSIN() and DGSSFS()
Option
Type of Matrix
Solver
'sp' or 'SP'
symmetric structure, positive-definite values
SPSOLVE
'ss' or 'SS'
symmetric structure, symmetric values
SPSOLVE
'su' or 'SU'
symmetric structure, unsymmetric values
SPSOLVE
'uu' or 'UU'
unsymmetric structure, unsymmetric values
SPSOLVE
's0' or 'S0'
SuperLU
A call to routine DGSSOR() must follow DGSSIN() to perform fill-reduce ordering and symbolic factorization. A character argument (ORDMTHD) is used to select the desired ordering method. This argument also exists in the one-call interface routine DGSSFS(). Valid ordering methods for SPSOLVE and SuperLU are listed in the following table. You can also provide a particular ordering to the solver by calling DGSSUO() in place of DGSSOR(). The input permutation array must be zero-based.
Table 8  Matrix Ordering Options for DGSSOR() and DGSSFS()
Option
Ordering Method
Solver
'nat' or 'NAT'
natural ordering (no ordering)
SPSOLVE, SuperLU
'mmd' or 'MMD'
minimum degree on A'*A (default)
SPSOLVE, SuperLU
'gnd' or 'GND'
general nested dissection
SPSOLVE
'spm' or 'SPM'
Minimum degree ordering on A'+A
SuperLU
'sam' or 'SAM'
Approximate minimum degree column
SuperLU
As shown above, the general nested dissection method is not available in SuperLU. On the other hand, the minimum degree ordering on A'+A and approximate minimum degree column ordering are not available in SPSOLVE.
SuperLU Examples
The following code examples show how SuperLU can be selected through the regular interface and the one-call interface of SPSOLVE to factorize and solve a general unsymmetric system of equations.
Example 8  Invoking SuperLU Through SPSOLVE Regular Interface
      program SLU
c  This program is an example driver that calls the regular interface of SPSOLVE
c  to invoke SuperLU to factor and solve a general unsymmetric system.
      implicit none
      integer           neqns, ier, msglvl, outunt, ldrhs, nrhs, i
      character         mtxtyp*2, pivot*1, ordmthd*3
      double precision  handle(150)
      integer           colstr(6), rowind(12)
      double precision  values(12), rhs(5), xexpct(5)
c  Sparse matrix structure and value arrays.  Coefficient matrix
c    is a general unsymmetric sparse matrix.
c    Ax = b, (solve for x) where:
c       1.0   0.0   7.0   9.0   0.0      1.0       17.0
c       2.0   4.0   0.0   0.0   0.0      1.0        6.0
c  A =  0.0   5.0   8.0   0.0   0.0  x = 1.0   b = 13.0
c       0.0   0.0   0.0  10.0  11.0      1.0       21.0
c       3.0   6.0   0.0   0.0  12.0      1.0       21.0
c  Array indices must be zero-based for calling SuperLU
      data colstr / 0, 3, 6, 8, 10, 12 /
      data rowind / 0, 1, 4, 1, 2, 4, 0, 2, 0, 3, 3, 4 /
      data values / 1.0, 2.0, 3.0,  4.0, 5.0,  6.0,
     $              7.0, 8.0, 9.0, 10.0, 11.0, 12.0 /
      data rhs    / 17.0, 6.0, 13.0, 21.0, 21.0 /
      data xexpct / 1.0d0, 1.0d0, 1.0d0, 1.0d0, 1.0d0 /
c  initialize solver
      mtxtyp= 's0'
      pivot = 'n'
      neqns  = 5
      outunt = 6
      msglvl = 0
c  call regular interface
      call dgssin(mtxtyp, pivot,  neqns , colstr, rowind,outunt, msglvl,
     &            handle, ier)
      if ( ier .ne. 0 ) goto 110
c  ordering and symbolic factorization
      ordmthd = 'mmd'
      call dgssor(ordmthd, handle, ier)
c  numeric factorization
      call dgssfa ( neqns, colstr, rowind, values, handle, ier )
c  solution
      nrhs   = 1
      ldrhs  = 5
      call dgsssl ( nrhs, rhs, ldrhs, handle, ier )
c  deallocate sparse solver storage
      call dgssda ( handle, ier )
c  print values of sol
      write(6,200) 'i', 'rhs(i)', 'expected rhs(i)', 'error'
      do i = 1, neqns
        write(6,300) i, rhs(i), xexpct(i), (rhs(i)-xexpct(i))
      enddo
      stop
  110 continue
c call to sparse solver returns an error
      write ( 6 , 400 )
     &      ' example: FAILED sparse solver error number = ', ier
      stop
  200 format(4x,a1,3x,a6,3x,a15,4x,a6)
  300 format(i5,3x,f5.2,7x,f5.2,8x,e10.2)     ! i/sol/xexpct values
  400 format(a60,i20)   ! fail message, sparse solver error number
      end
my_system% f95 -dalign slu.f -library=sunperf
my_system% a.out
    i   rhs(i)   expected rhs(i)     error
    1    1.00        1.00          0.00E+00
    2    1.00        1.00         -0.33E-15
    3    1.00        1.00          0.22E-15
    4    1.00        1.00         -0.11E-15
    5    1.00        1.00          0.22E-15
Example 9  Invoking SuperLU through One-Call SPSOLVE Interface
program SLU_SINGLE
      implicit none
c  initialize solver
      mtxtyp= 's0'
      pivot = 'n'
      neqns  = 5
      outunt = 6
      msglvl = 0
      ordmthd = 'mmd'
      nrhs = 1
      ldrhs = 5
c  One-call routine of SPSOLVE
      call dgssfs (mtxtyp, pivot, neqns , colstr, rowind,
     &             values, nrhs , rhs, ldrhs , ordmthd,
     &             outunt, msglvl, handle, ier)
      do i = 1, neqns
      enddo
      stop
  110 continue
      write ( 6 , 400 )
      stop
      end
my_system% f95 -dalign slu_single.f -library=sunperf
my_system% a.out
