Go to main content
Oracle® Developer Studio 12.6: Performance Library User's Guide
Exit Print View
Updated: July 2017
Cosine and Sine Transforms
Input to the DFT that possess special symmetries occur in various applications. A transform that exploits symmetry usually saves in storage and computational count, such as with the real-to-complex and complex-to-real FFT transforms. The Performance Library cosine and sine transforms are special cases of FFT routines that take advantage of the symmetry properties found in even and odd functions.
Note - Oracle Developer Studio Performance Library sine and cosine transform routines are based on the routines contained in FFTPACK (http://www.netlib.org/fftpack/). Routines with a V prefix are vectorized routines that are based on the routines contained in VFFTPACK (http://www.netlib.org/vfftpack/).
Fast Cosine and Sine Transform Routines
The following tables list the Oracle Developer Studio Performance Library fast cosine and sine transforms. Names of double precision routines are in square brackets. Routines whose name begins with 'V' can compute the transform of one or more sequences simultaneously. Those whose name ends with 'I' are initialization routines.
Table 15  Fast Cosine Transforms for Even Sequences Routines and Their Arguments
Routine Name
Arguments
COST [DCOST]
(LEN+1, X, WORK)
COSTI [DCOSTI]
(LEN+1, WORK)
VCOST [VDCOST]
(M, LEN+1, X, WORK, LD, TABLE)
VCOSTI [VDCOSTI]
(LEN+1, TABLE)
Table 16  Fast Cosine Transforms for Quarter-Wave Even Sequences Routines and Their Arguments
Routine Name
Arguments
COSQF [DCOSQF]
(LEN, X, WORK)
COSQB [DCOSQB]
(LEN, X, WORK)
COSQI [DCOSQI]
(LEN, WORK)
VCOSQF [VDCOSQF]
(M, LEN, X, WORK, LD, TABLE)
VCOSQB [VDCOSQB]
VCOSQI [VDCOSQI]
(LEN, TABLE)
Table 17  Fast Sine Transforms for Odd Sequences Routines and Their Arguments
Routine Name
Arguments
SINT [DSINT]
(LEN-1, X, WORK)
SINTI [DSINTI]
(LEN-1, WORK)
VSINT [VDSINT]
(M, LEN-1, X, WORK, LD, TABLE)
VSINTI [VDSINTI]
(LEN-1, TABLE)
Table 18  Fast Sine Transforms for Quarter-Wave Odd Sequences Routines and Their Arguments
Routine Name
Arguments
SINQF [DSINQF]
(LEN, X, WORK)
SINQB [DSINQB]
(LEN, X, WORK)
SINQI [DSINQI]
(LEN, WORK)
VSINQF [VDSINQF]
VSINQB [VDSINQB]
VSINQI [VDSINQI]
(LEN, TABLE) Notes:
Note -  Note the following information about the previous tables:
  • M: Number of sequences to be transformed.
  • LEN, LEN-1, LEN+1: Length of the input sequence or sequences.
  • X: A real array which contains the sequence or sequences to be transformed. On output, the real transform results are stored in X.
  • TABLE: Array of constants particular to a transform size that is required by the transform routine. The constants are computed by the initialization routine.
  • WORK: Workspace required by the transform routine. In routines that operate on a single sequence, WORK also contains constants computed by the initialization routine.
Another type of symmetry that is commonly encountered is the odd symmetry where x(n) = -x(-n) for n = -N+1, …, 0, …, N. As in the case of the fast cosine transform, the fast sine transform (FST) takes advantage of the odd symmetry to save memory and computation. For a real odd sequence x, symmetry implies that x(0) = -x(0) = 0. Therefore, if x is of length 2N then only N = 1 values of x are required to compute the FST. Routine SINT computes the FST of a single real odd sequence while VSINT computes the FST of one or more sequences. Before calling [V]SINT, [V]SINTI must be called to compute trigonometric constants and factors associated with input length N-1. The FST is its own inverse transform. Calling VSINT twice will result in the original N -1 data points. Calling SINT twice will result in the original N-1 data points multiplied by 2N.
An odd sequence with symmetry such that x(n) = -x(-n - 1), where -N+1, …, 0, …, N is said to have quarter-wave odd symmetry. SINQF and SINQB compute the FST and its inverse, respectively, of a single real quarter-wave odd sequence while VSINQF and VSINQB operate on one or more sequences. SINQB is unnormalized, so using the results of SINQF as input in SINQB produces the original sequence scaled by a factor of 4N. However, VSINQB is normalized, so a call to VSINQF followed by a call to VSINQB will produce the original sequence. An FST of a real sequence of length 2N that has quarter-wave odd symmetry requires N input data points and produces an N-point resulting sequence. Initialization is required before calling the transform routines by calling [V]SINQI.
A special form of the FFT that operates on real even sequences is the fast cosine transform (FCT). A real sequence x is said to have even symmetry if x(n) = x(-n) where n = -N + 1, …, 0, …, N. An FCT of a sequence of length 2N requires N + 1 input data points and produces a sequence of size N + 1. Routine COST computes the FCT of a single real even sequence while VCOST computes the FCT of one or more sequences. Before calling [V]COST, [V]COSTI must be called to compute trigonometric constants and factors associated with input length N + 1. The FCT is its own inverse transform. Calling VCOST twice will result in the original N +1 data points. Calling COST twice will result in the original N +1 data points multiplied by 2N.
An even sequence x with symmetry such that x(n) = x(-n - 1) where n = ‐N + 1, … , 0, …, N is said to have quarter-wave even symmetry. COSQF and COSQB compute the FCT and its inverse, respectively, of a single real quarter-wave even sequence. VCOSQF and VCOSQB operate on one or more sequences. The results of [V]COSQB are unnormalized, and if scaled by image:Scaling of the results of VCOSQB the original sequences are obtained. An FCT of a real sequence of length 2N that has quarter-wave even symmetry requires N input data points and produces an N-point resulting sequence. Initialization is required before calling the transform routines by calling [V]COSQI.
Discrete Fast Cosine and Sine Transforms and Their Inverse
Oracle Developer Studio Performance Library routines use the equations in the following sections to compute the fast cosine and sine transforms and inverse transforms.
[D]COST: Forward and Inverse Fast Cosine Transform (FCT) of a Sequence
The forward and inverse FCT of a sequence is computed as:
image:X(k) = x(0) + 2 times sum to {N-1} from {n=1} x(n) cos((%pi nk)                             over N) + x(N) cos(%pi k), k=0,...,N
[D]COST Notes:
  • N + 1 values are needed to compute the FCT of an N-point sequence.
  • [D]COST also computes the inverse transform. When [D]COST is called twice, the result will be the original sequence scaled by image:Scaling of the original sequence
V[D]COST: Forward and Inverse Fast Cosine Transforms of Multiple Sequences (VFCT)
The forward and inverse FCTs of multiple sequences are computed as:
For i = 0, M - 1
image:X(i,k) = {x(i,0)}over 2N + 1 over N sum to {N - 1} from {n=1}                             x(i,n) cos ({%pi nk} over N ) + x(i,N) over 2N cos(%pi k), k= 0, ...,                             N1 .
V[D]COST Notes
  • M × (N+1) values are needed to compute the VFCT of M N-point sequences.
  • The input and output sequences are stored row-wise.
  • V[D]COST is normalized and is its own inverse. When V[D]COST is called twice, the result will be the original data.
[D]COSQF: Forward FCT of a Quarter-Wave Even Sequence
The forward FCT of a quarter-wave even sequence is computed as:
image:X(k)= x(0)+ 2 sum to {N - 1} from {n = 1} x(n) cos({%pi (2k+1)}                             over 2N), k= 0, ..., N - 1
N values are needed to compute the forward FCT of an N-point quarter-wave even sequence.
[D]COSQB: Inverse FCT of a Quarter-Wave Even Sequence
The inverse FCT of a quarter-wave even sequence is computed as
image:x(n) = sum to {N - 1} from {k = 0} X(k) cos ({%pi n(2k + 1)} over                             2N ), n = 0,...,N - 1 .
Calling the forward and inverse routines will result in the original input scaled by image:Scaling of original input .
V[D]COSQF: Forward FCT of One or More Quarter-Wave Even Sequences
The forward FCT of one or more quarter-wave even sequences is computed as
For i = 0, M - 1
image:X(i,k) = 1 over N [ x(i,0)+ 2 sum to {N - 1} from {n = 1} x(i,n)                             cos ({%pi n(2k + 1)} over 2N )], k = 0, ..., N - 1
V[D]COSQF Notes:
  • The transform is normalized so that if the inverse routine V[D]COSQB is called immediately after calling V[D]COSQF, the original data is obtained.
V[D]COSQB: Inverse FCT of One or More Quarter-Wave Even Sequences
The inverse FCT of one or more quarter-wave even sequences is computed as
For i = 0, M - 1
image:x(i,n) = sum to {N - 1} from {k = 0} X(i,k) cos ({%pi n(2k + 1)}                             over 2N), n = 0,...,N - 1
V[D]COSQB Notes:
  • The transform is normalized so that if V[D]COSQB is called immediately after calling V[D]COSQF, the original data is obtained.
[D]SINT: Forward and Inverse Fast Sine Transform (FST) of a Sequence
The forward and inverse FST of a sequence is computed as
image:X(k) = 2 times sum to {N - 2} from {n = 0} x(n) sin ({%pi                             (n+1)(k+1)} over N), k = 0,...,N - 2 .
[D]SINT Notes:
  • N-1 values are needed to compute the FST of an N-point sequence.
  • [D]SINT also computes the inverse transform. When [D]SINT is called twice, the result will be the original sequence scaled by image:Scaling of original sequence .
V[D]SINT: Forward and Inverse Fast Sine Transforms of Multiple Sequences (VFST)
The forward and inverse fast sine transforms of multiple sequences are computed as
For i = 0, M - 1
image:X(i,k) = (2 over sqrt 2N) times sum to {N - 2} from {n = 0} x(i,n)                             sin ({%pi (n+1)(k+1)} over N), k = 0,...,N - 2 .
V[D]SINT Notes:
  • M × (N - 1) values are needed to compute the VFST of M N-point sequences.
  • V[D]SINT is normalized and is its own inverse. Calling V[D]SINT twice yields the original data.
[D]SINQF: Forward FST of a Quarter-Wave Odd Sequence
The forward FST of a quarter-wave odd sequence is computed as
image:X(k) = 2 times sum to {N - 2} from {n = 0} x(n) sin ({%pi                             (n+1)(2k+1)} over 2N ) + x(N - 1) cos(%pi k), k = 0,...,N - 1 .
N values are needed to compute the forward FST of an N-point quarter-wave odd sequence.
[D]SINQB: Inverse FST of a Quarter-Wave Odd Sequence
The inverse FST of a quarter-wave odd sequence is computed as
image:Inverse FST of a Quarter-Wave Odd Sequence .
V[D]SINQF: Forward FST of One or More Quarter-Wave Odd Sequences
The forward FST of one or more quarter-wave odd sequences is computed as
For i = 0, M - 1
image:X(i,k) = 1 over sqrt 4N times [ 2 sum to {N - 2} from {n = 0}                             x(n,i) sin ({%pi (n+1)(2k+1)} over 2N ) + x(N - 1,i) cos %pi k  ], k =                             0, ...,N - 1 .
V[D]SINQF Notes:
  • The transform is normalized so that if the inverse routine V[D]SINQB is called immediately after calling V[D]SINQF, the original data is obtained.
V[D]SINQB: Inverse FST of One or More Quarter-Wave Odd Sequences
The inverse FST of one or more quarter-wave odd sequences is computed as
For i = 0, M - 1
image:x(n,i) = 4 over sqrt 4N times sum to {N - 1} from {k = 0} X(k,i)                             sin ({%pi (n+1)(2k+1)} over 2N ), n = 0, ...,N - 1 .
V[D]SINQB Notes:
  • The transform is normalized, so that if V[D]SINQB is called immediately after calling V[D]SINQF, the original data is obtained.
Fast Cosine Transform Examples
Example 15 calls COST to compute the FCT and the inverse transform of a real even sequence. If the real sequence is of length 2N, only N + 1 input data points need to be stored and the number of resulting data points is also N + 1. The results are stored in the input array.
Example 15  Computer FCT and Inverse FCT of Single Real Even Sequence
my_system% cat cost.f
       program Drive cost
       implicit none
       integer,parameter :: len=4
       real x(0:len),work(3*(len+1)+15), z(0:len), scale
       integer i
       scale = 1.0/(2.0*len)
       call RANDOM_NUMBER(x(0:len))
       z(0:len) = x(0:len)
         write(*,'(a25,i1,a10,i1,a12)')'Input sequence of length ',
     $          len,' requires ', len+1,' data points'
       write(*,'(5(f8.3,2x),/)')(x(i),i=0,len)
       call costi(len+1, work)
       call cost(len+1, z, work)
       write(*,*)'Forward fast cosine transform'
       write(*,'(5(f8.3,2x),/)')(z(i),i=0,len)
       write(*,*)
     $    'Inverse fast cosine transform (results scaled by 1/2*N)'
       write(*,'(5(f8.3,2x),/)')(z(i)*scale,i=0,len)
       end
my_system% f95 -dalign cost.f -library=sunperf
my_system% a.out
Input sequence of length 4 requires 5 data points
0.557 0.603 0.210 0.352 0.867
3.753 0.046 1.004 -0.666 -0.066
Example 16 calls VCOSQF and VCOSQB to compute the FCT and the inverse FCT, respectively, of two real quarter-wave even sequences. If the real sequences are of length 2N, only N input data points need to be stored, and the number of resulting data points is also N. The results are stored in the input array.
Example 16  Compute the FCT and the Inverse FCT of Two Real Quarter-wave Even Sequences
my_system% cat vcosq.f
    program vcosq
    implicit none
    integer,parameter :: len=4, m = 2, ld = m+1
    real x(ld,len),xt(ld,len),work(3*len+15), z(ld,len)
    integer i, j
    call RANDOM_NUMBER(x)
    z = x
    write(*,'(a27,i1)')' Input sequences of length ',len
    do j = 1,m
       write(*,'(a3,i1,a4,4(f5.3,2x),a1,/)')
 $     'seq',j,' = (',(x(j,i),i=1,len),')'
    end do
    call vcosqi(len, work)
    call vcosqf(m,len, z, xt, ld, work)
    write(*,*)
 $ 'Forward fast cosine transform for quarter-wave even sequences'
    do j = 1,m
 $     'seq',j,' = (',(z(j,i),i=1,len),')'
    end do
    call vcosqb(m,len, z, xt, ld, work)
    write(*,*)
 $  'Inverse fast cosine transform for quarter-wave even sequences'
    write(*,*)'(results are normalized)'
    do j = 1,m
    end do
    end
my_system% f95 -dalign vcosq.f -library=sunperf
my_system% a.out
Input sequences of length 4
seq1 = (0.557 0.352 0.990 0.539 )
seq2 = (0.603 0.867 0.417 0.156 )
seq1 = (0.755 -.392 -.029 0.224 )
seq2 = (0.729 0.097 -.091 -.132 )
Fast Sine Transform Examples
In the following example Example 17, SINT is called to compute the FST and the inverse transform of a real odd sequence. If the real sequence is of length 2N, only N - 1 input data points need to be stored and the number of resulting data points is also N - 1. The results are stored in the input array.
Example 17  Compute the FCT and the Inverse FCT of Two Real Quarter-wave Even Sequences
my_system% cat sint.f
      program Drive sint
      implicit none
      real x(0:len-2),work(3*(len-1)+15), z(0:len-2), scale
      integer i
      call RANDOM_NUMBER(x(0:len-2))
      z(0:len-2) = x(0:len-2)
    $       len,' requires ', len-1,' data points'
      write(*,'(3(f8.3,2x),/)')(x(i),i=0,len-2)
      call sinti(len-1, work)
      call sint(len-1, z, work)
      write(*,*)'Forward fast sine transform'
      write(*,'(3(f8.3,2x),/)')(z(i),i=0,len-2)
      write(*,*)
     $ 'Inverse fast sine transform (results scaled by 1/2*N)'
      write(*,'(3(f8.3,2x),/)')(z(i)*scale,i=0,len-2)
      end
my_system% f95 -dalign sint.f -library=sunperf
my_system% a.out
Input sequence of length 4 requires 3 data points
0.557 0.603 0.210
2.291 0.694 -0.122
0.557 0.603 0.210
In the following example Example 18, VSINQF and VSINQB are called to compute the FST and inverse FST, respectively, of two real quarter-wave odd sequences. If the real sequence is of length 2N, only N input data points need to be stored and the number of resulting data points is also N. The results are stored in the input array.
Example 18  Compute FST and Inverse FST of Two Real Quarter-Wave Odd Sequences
my_system% cat vsinq.f
      program vsinq
      implicit none
      integer i, j
      z = x
      do j = 1,m
      end do
      call vsinqi(len, work)
      call vsinqf(m,len, z, xt, ld, work)
      write(*,*)
    $ 'Forward fast sine transform for quarter-wave odd sequences'
      do j = 1,m
      end do
      call vsinqb(m,len, z, xt, ld, work)
      write(*,*)
    $ 'Inverse fast sine transform for quarter-wave odd sequences'
      do j = 1,m
      end do
      end
my_system% f95 vsinq.f -library=sunperf
my_system% a.out
seq1 = (0.823 0.057 0.078 0.305 )
seq2 = (0.654 0.466 -.069 -.037 )
