Go to main content
Oracle® Rack Cabinet 1242 Power Distribution Units User's Guide
Exit Print View
Updated: March 2018
Monitor the Enhanced PDU (RS-232)
Using the metering unit's RS-232, you can monitor how much power, energy, and current the equipment attached to the PDU uses, as well as the voltage level powering the equipment.
  1. Connect an RS-232 cable between the SER MGT port and the host.
  2. Configure the host's terminal or terminal emulator with settings.
    See Terminal Configuration Settings.
  3. When prompted, log in as an admin or user.
    See Login Information.
  4. Familiarize yourself with the command options.
    See Understanding CLI Commands.
