When you connect to an Oracle8 database server, a Types node under the Database Objects node enables you to display and find Oracle8 user-defined datatypes and their associated attributes and methods.
Oracle8 functionality in the Tables node and Views node enables you to view object tables, column objects, and object views and their associated Instead Of triggers.
