Introducing Procedure Builder BACK | 1 2 3 4 5 6 7 8 9 | NEXT | MAIN
In this topic you learned that the Object Navigator:
  • Provides a hierarchical listing of your PL/SQL objects, including a Types node supporting Oracle8 user-defined datatypes.
  • Allows you to browse and modify object relationships.
  • Allows you to create and search for any object in the hierarchy.
The next topic, Developing a Program Unit, describes how to use the Program Unit editor in all stages of the program unit development cycle.
