Applications Administration Guide > Audit Trail >
Specifying Audit Trail Restrictions
You can restrict who gets audited by user, position, or responsibility. For example, if you set the Restriction Type to "Users" on the Audit Trail Buscomp Fields view, you then go to the Audit Trail Users View and add the users whom you want to audit. Restriction by responsibility or position works in the same way. This task is a step in Process of Configuring and Using Audit Trail. To restrict by user
- Navigate to Administration - Audit Trail screen.
- Select a business component entry in the Audit Trail Buscomp list, and click the User view tab.
- In the Audit Trail Buscomp list, change the Restriction Type field to User.
- Select the Audit Trail User list, and create or edit records.
Only these users are audited for the operations on this particular business component.
- If you:
- Changed the Restriction Type field in Step 3 (for example from No Restriction to User), then restart the Application Object Manager so that the changes take effect.
- Only created or changed users, then start a new session to see the changes take effect.
To restrict by position
- Select a business component entry in the Audit Trail Buscomp list, and click the Position view tab.
- In the Audit Trail Buscomp list, change the Restriction Type field to Position.
- Select the Audit Trail Position list, and create or edit records.
Only these positions are audited for this particular business component.
- If you:
- Changed the Restriction Type field in Step 3 (for example from No Restriction to Position), then restart the Application Object Manager so that the changes take effect.
- Only created or changed positions, then start a new session to see the changes take effect.
To restrict by responsibility
- Select a business component entry in the Audit Trail Buscomp list, and click the Responsibility view tab.
- In the Audit Trail Buscomp list, change the Restriction Type field to Responsibility.
- Select the Audit Trail Responsibility list, and create or edit records.
Only these responsibilities are audited for this particular business component.
- If you:
- Changed the Restriction Type field in Step 3 (for example from No Restriction to Responsibility), then restart the Application Object Manager so that the changes take effect.
- Only created or changed responsibilities, then start a new session to see the changes take effect.
