Applications Administration Guide > Audit Trail > Configuring Audit Trail in Siebel ToolsThe Audit Trail functionality is not enabled in the preconfigured application. By enabling the Audit Trail business service with Siebel Tools, Audit Trail becomes available to application objects. You can turn off the Audit Trail for individual applications by deactivating the Audit Trail application event service for the application. For workflows, the Audit Trail function will not work unless the Start Method of the Audit Trail Engine Business Service is included as a first step in the workflow process. For more information, see About the Audit Trail Engine Business Service. NOTE: Audit Trail does not create history records for predefault values; predefault values are assumed to be part of the initial record. If, however, the default values are changed at a later date and those fields are set to be audited, then both the original and changed values are recorded. Enabling the Audit Trail Engine Business ServiceThis task is a step in Process of Configuring and Using Audit Trail. To enable the Audit Trail Engine business service
Disabling Audit Trail for an ApplicationThis task is a step in Process of Configuring and Using Audit Trail. To disable Audit Trail for an application
Configuring an Application for Audit TrailUse the following procedure to enable a customized application object for auditing, or to re-enable an application object that has been turned off. To configure an application for Audit Trail
About Using Audit Trail with Object InterfacesWhen accessing an Application Object Manager through object interfaces such as COM Data Control and Java Data Bean, Audit Trail is not started automatically. In these cases, you must invoke the Audit Trail Engine business service explicitly. |
| Applications Administration Guide |
