Applications Administration Guide > Audit Trail >
Specifying Business Components and Business Component Fields for Audit
You administer the business component and the business component fields to be audited. This task is a step in Process of Configuring and Using Audit Trail. To configure the business component and business component fields to be audited
- Navigate to the Administration - Audit Trail screen.
- In the Audit Trail Buscomp list, create a new record and complete the necessary fields.
Some fields are described in the following table.
Assoc |
Specifies whether to audit associations with the child business components in the Child Buscomp list. See Specifying Parent-Child Associations for Audit. |
Copy |
Select if you want to audit the Copy operation. |
End Date |
Date on which the auditing stops. Turn Audit Trail off for an individual business component by setting the End Date to a date that has already passed. |
New |
Select if you want to audit the New operation. |
Restriction Type |
Specifies whether there is a rule determining who gets audited. |
Start Date |
Date on which the auditing starts. |
Update |
Select if you want to audit the Update operation. |
- In the Field list, create a new record for the field you want to audit.
- Repeat Step 3 until the Field list shows all the fields in that business component that you want to audit.
NOTE: For any audit trail deployment, the combination of the number of fields audited, and the number of audit records created by a given business process, has performance implications. Auditing a large number of fields on a business component, or auditing fields in a large number of business components, may produce unacceptable performance that is counter to the overall business requirement.
To disable individual business components
- Navigate to Administration - Audit Trail screen.
- Use one of the following methods to disable Audit Trail:
- In the Audit Trail Buscomp list, enter an end date prior to today's date in the End Date field.
- In the Audit Trail Buscomp list, delete the record for the business component.
