Bookshelf Home | Contents | Index | PDF | ![]() ![]() |
Applications Administration Guide > Global Target List Management > About Configuring Target Lists > Setting Up Data Map Object "Activity Templates" for Target ListsSome activity template data map objects are provided in seed data. (These are listed in Step 4.) You can edit these objects or create your own objects, using those provided as a model. For more information about Data Map Objects, see Siebel Finance Guide. |
Applications Administration Guide |
