Bookshelf Home | Contents | Index | PDF | ![]() ![]() |
Applications Administration Guide > State Models > Configuring Business Components for State ModelsYou can create state models on business components that are:
Creating state models for business components based on subclasses of CSSBCBase class is not supported by Siebel Systems. In particular, do not create or modify state models on the Enterprise Service Definitions, SRM Request, and SRM Repeating Request business components. These are used for server administration. This task is a step in Process of Setting Up State Models. To find out if a business component is already enabled for state models
To enable a business component for state models functionality in Siebel Tools |
Applications Administration Guide |
