Siebel Assignment Manager Administration Guide > Advanced Assignment Manager Configuration > Process of Configuring Assignment Manager to Copy Columns > Configuring Assignment Objects to Copy ColumnsUsing Siebel Tools, you can configure assignment objects to copy position-specific or employee-specific data. Typically, you configure sales objects to copy position-specific data and you configure service objects to copy employee specific data. This task is one step in Process of Configuring Assignment Manager to Copy Columns. By default, the TM Account assignment object is predefined to copy position-specific data. Figure 32 shows the TM Account assignment object configured to copy only a single column—ROLE_CD. Use the following procedure to add either the Position Specific Columns or Employee Specific Columns user property to an assignment object for which you want to enable copying of data. To configure an assignment object to copy position- or employee-specific data
After the assignment object is modified, you must run various server administration procedures to make sure your configurations are recognized by Assignment Manager.
After the assignment object is configured, you can then instruct Assignment Manager to copy position- or employee-specific data using the UI or by submitting a server component job from the command-line interface. |
| Siebel Assignment Manager Administration Guide |
