Siebel Assignment Manager Administration Guide > Working with Dynamic Candidates > Process of Defining Dynamic Candidates > Copying Dynamic Candidate Attribute Columns to the Team TableAssignment Manager supports copying of dynamic candidate attribute columns and stamping of attributes on each candidate obtained through a join on the team table by copying dynamic candidate attribute values at any level in an n-level join to the results team table. You can create multiple entries to create joins. One of those entries you flag as the candidate table. The source table for that record is the team table for that dynamic candidate. This task is an optional step in Process of Defining Dynamic Candidates. Use the following procedure to specify the column name in the results table where you want the attribute values stamped. NOTE: You can write results to both reporting or operational tables. To copy dynamic candidate attribute columns to the team table
Table 42 provides descriptions of some of the Dynamic Candidate Component Col object properties. |
| Siebel Assignment Manager Administration Guide |
