| Siebel Communications Guide > Defining Integration Workflows for Siebel Communications  >  Sample Integration Workflows for Siebel Communications
 This section lists the sample integration workflow processes and indicates which business services, integration objects, and methods are used for each step.  NOTE:  Sample workflows must be imported into your database. For instructions on importing these workflows, see Siebel Business Process Designer Administration Guide. Some workflow process steps call other workflow processes. For example, Step 1 of the CUT Send Account Data workflow process calls the CUT Get Account Data workflow process. In this example, the CUT Get Account Data workflow process is a subprocess of the CUT Send Account Data workflow process (see Table 14). Some sample workflow processes communicate using the Siebel EAI MQ Series Transport. If your company does not use MQ Series, you can replace the appropriate step with one that uses either a custom transport business service, the provided HTTP business service, or the provided XML file business service. Business services are located in the Siebel Tools repository and are available for use when defining workflow processes. The integration objects used in the samples are:
CUT Sample Account IO
CUT Sample Asset IO
CUT Sample Credit Alert IO
CUT Sample Fraud Alert IO
CUT Sample Sales Order IO
CUT Sample Service Profile IO
CUT Sample Trouble Ticket IO
CUT Sample Work Order IO
 NOTE:  The Integration Object mentioned in this section is specified in XML. It is not specified as a Business Service Input Argument. CUT Send Account DataTable 14 shows the steps for the CUT Send Account Data workflow process.
Table 14.  CUT Send Account Data Workflow Process Steps
    | Step Name | Get Account Data | Send Account Data |
    | Subprocess Name | CUT Get Account Data |   |
    | Business Service |   | EAI MQSeries Server Transport |
    | Integration Object |   |   |
    | Method |   | Send |
 CUT Get Account DataTable 15 shows the steps for the CUT Get Account Data workflow subprocess.
Table 15.  CUT Get Account Data Workflow Process Steps
    | Step Name | Get Account Data | Convert to XML |
    | Subprocess Name |   |   |
    | Business Service | EAI Siebel Adapter | EAI XML Converter |
    | Integration Object | CUT Sample Account IO |   |
    | Method | Query | Integration Object Hierarchy to XML Document |
 CUT Receive Account DataTable 16 shows the steps for the CUT Receive Account Data workflow process.
Table 16.  CUT Receive Account Data Workflow Process Steps
    | Step Name | Receive Account Update | Convert to Internal | Update Account |
    | Subprocess Name |   |   |   |
    | Business Service | EAI MQSeries Server Transport | EAI XML Converter | EAI Siebel Adapter |
    | Integration Object |   |   |   |
    | Method | Receive | XML Document to Integration Object Hierarchy | Insert or Update |
 CUT Send Service Profile DataTable 17 shows the steps for the CUT Send Service Profile Data workflow process.
Table 17.  CUT Send Service Profile Data Workflow Process Steps
    | Step Name | Get Service Profile Data | Send Service Profile Data |
    | Subprocess Name | CUT Get Service Profile Data |   |
    | Method |   | Send |
 CUT Get Service Profile DataTable 18 shows the steps for the CUT Get Service Profile Data workflow subprocess.
Table 18.  CUT Get Service Profile Data Workflow Process Steps
    | Step Name | Get Service Profile Data | Convert to XML |
    | Integration Object | CUT Sample Service Profile IO |   |
 CUT Receive Service Profile DataTable 19 shows the steps for the CUT Receive Service Profile Data workflow process.
Table 19.  CUT Receive Service Profile Data Workflow Process Steps
    | Step Name | Receive Service Profile Update | Convert to Internal | Update Service Profile |
 CUT Get Sales Order DataTable 20 shows the steps for the CUT Get Sales Order Data workflow process.
Table 20.  CUT Get Sales Order Data Workflow Process Steps
    | Step Name | Get Sales Order Data | Convert to XML |
    | Integration Object | CUT Sample Sales Order IO |   |
 CUT Send Sales Order DataTable 21 shows the steps for the CUT Send Sales Order Data workflow process.
Table 21.  CUT Send Sales Order Data Workflow Process Steps
    | Step Name | Get Sales Order Data | Send Sales Order Data |
    | Subprocess Name | CUT Get Sales Order Data |   |
    | Method |   | Send |
 CUT Receive Sales Order DataTable 22 shows the steps for the CUT Receive Sales Order Data workflow process.
Table 22.  CUT Receive Sales Order Data Workflow Process Steps
    | Step Name | Receive Sales Order Update | Convert to Internal | Update Sales Order |
 CUT Get Work Order DataTable 23 shows the steps for the CUT Get Work Order Data workflow process.
Table 23.  CUT Get Work Order Data Workflow Process Steps
    | Step Name | Get Work Order Data | Convert to XML |
    | Integration Object | CUT Sample Work Order IO |   |
 CUT Send Work Order DataTable 24 shows the steps for the CUT Send Work Order Data workflow process.
Table 24.  CUT Send Work Order Data Workflow Process Steps
    | Step Name | Get Work Order Data | Send Work Order Data |
    | Subprocess Name | CUT Get Work Order Data |   |
    | Method |   | Send |
 CUT Receive Work Order DataTable 25 shows the steps for the CUT Receive Work Order Data workflow process.
Table 25.  CUT Receive Work Order Data Workflow Process Steps
    | Step Name | Receive Work Order Update | Convert to Internal | Update Work Order |
 CUT Get Trouble Ticket DataTable 26 shows the steps for the CUT Get Trouble Ticket Data workflow process.
Table 26.  CUT Get Trouble Ticket Data Workflow Process Steps
    | Step Name | Get Trouble Ticket Data | Convert to XML |
    | Integration Object | CUT Sample Trouble Ticket IO |   |
 CUT Send Trouble Ticket DataTable 27 shows the steps for the CUT Send Trouble Ticket Data workflow process.
Table 27.  CUT Send Trouble Ticket Data Workflow Process Steps
    | Step Name | Get Trouble Ticket Data | Send Trouble Ticket Data |
    | Subprocess Name | CUT Get Trouble Ticket Data |   |
    | Method |   | Send |
 CUT Receive Trouble Ticket DataTable 28 shows the steps for the CUT Receive Trouble Ticket Data workflow process.
Table 28.  CUT Receive Trouble Ticket Data Workflow Process Steps
    | Step Name | Receive Trouble Ticket Update | Convert to Internal | Update Trouble Ticket |
 CUT Receive Fraud Alert DataTable 29 shows the steps for the CUT Receive Fraud Alert Data workflow process.
Table 29.  CUT Receive Fraud Alert Data Workflow Process Steps
    | Step Name | Receive Fraud Alert Update | Convert to Internal | Update Fraud Alert |
 CUT Receive Credit Alert DataTable 30 shows the steps for the CUT Receive Credit Alert Data workflow process.
Table 30.  CUT Receive Credit Alert Data Workflow Process Steps
    | Step Name | Receive Credit Alert Update | Convert to Internal | Update Credit Alert |
 CUT Get Phone Number DataTable 31 shows the steps for the CUT Get Phone Number Data workflow process.
Table 31.  CUT Get Phone Number Data Workflow Process Steps
    | Step Name | Get Phone Number Data | Convert to XML |
    | Integration Object | CUT Sample Asset IO |   |
 CUT Send Phone Number DataTable 32 shows the steps for the CUT Send Phone Number Data workflow process.
Table 32.  CUT Send Phone Number Data Workflow Process Steps
    | Step Name | Get Phone Number Data | Send Phone Number Data |
    | Subprocess Name | CUT Get Phone Number Data |   |
    | Method |   | Send |
 CUT Receive Phone Number DataTable 33 shows the steps for the CUT Receive Phone Number Data workflow process.
Table 33.  CUT Receive Phone Number Data Workflow Process Steps
    | Step Name | Receive Phone Number Update | Convert to Internal | Update Phone Number |
