| Bookshelf Home | Contents | Index | PDF |    |
| Siebel Communications Guide > Defining Integration Workflows for Siebel Communications > Sample Integration Workflow: CUT Send Account DataThis section examines a send-type sample workflow process to help you understand how the workflow process is set up. The CUT Send Account Data workflow process sends an XML string, created from an account record, to an IBM MQSeries queue. This workflow process is shown in Figure 18. CUT Send Account Data Workflow PropertiesProperties that apply to all steps of a workflow process are called workflow process properties. These properties apply to all workflow processes: The CUT Send Account Data workflow has these additional properties:
 CUT Send Account Data Workflow StepsCUT Send Account Data Workflow includes the steps described in this section. Get Account Data Subprocess StepThe first step after Start is the Get Account Data subprocess. This subprocess is shown in contains two steps: This subprocess is shown in Figure 19. Get Account Data StepThis step uses the query method of the Siebel EAI Adapter to get an instance of an account record from the Siebel database. The CUT Sample Account IO describes the structure of the Account business object and was created using the Integration Object Builder. The other part of the query criteria is the Object Id, which is a process property that contains the row ID for the account in the sample DB. NOTE: The CUT Sample Account IO value is actually specified as a process property that is used as the input argument for the process step. Convert to XML StepThis step uses the Integration Object Hierarchy to XML Document method of the EAI XML Converter to convert the outbound Siebel Message to XML and store it in the Account XML output argument. Send StepThe last step in the CUT Send Account Data workflow process before End invokes the EAI MQSeries Server Transport to put the XML message onto the MQSeries queue, called Employee. The message is represented by the Message Text argument. The Queue Manager Name and Physical Queue Name are defined during the MQSeries setup. The Account XML message is sent to the queue specified by the Physical Queue Name property, which is managed by the queue manager specified in the Queue Manager Name property. |
| Siebel Communications Guide |
