Configuring Siebel eBusiness Applications > Configuring Keyboard Accelerators >
Modifying Key Sequence
You can modify the key sequence for an existing accelerator. To modify the Key Sequence for an accelerator
- Navigate to the Commands object in the Object Explorer view.
- Identify and highlight the command to modify.
- Select the accelerator that you want to modify (Accelerator is a child object of the Command object).
- Modify the Key Sequence property for the accelerator.
See Guidelines for Configuring Keyboard Accelerators.
- Compile and check-in the project.
