Configuring Siebel eBusiness Applications > Configuring Applets > About Applet Controls and List Columns >
Check Box Controls
A check box is implemented as a control with a HTML Type property setting of CheckBox. A check box is used to represent a TRUE/FALSE field with a data type of DTYPE_BOOL. When you click an empty box, a check mark or an X appears in the box. If you click a box that is checked, the check mark or X disappears. An example of a check box appears in Figure 55.
Figure 55. Check Box Control
