Integration Platform Technologies: Siebel Enterprise Application Integration > Siebel Virtual Business Components > Custom Business Service Methods >
Common Method Parameters
Table 44 shows the input parameters common to every method. Note that all these parameters are at the root property set.
Table 44. Common Input Parameters
Remote Source |
(Optional) Specifies the name of an external data source. This is the VBC's Remote Source user property, if defined. For information, see Table 37. |
Business Component Name |
Name of the active VBC. |
Business Component Id |
Internally generated unique value that represents the VBC. |
Parameters |
(Optional) The VBC's Service Parameters user property, if defined. For information, see Table 37. A set of parameters required by the business service. |
VBC Compatibility Mode |
(Optional) This is the VBC's Compatibility Mode user property, if defined. For information, see Table 37. |
When a response has been received, the method packages the response from the external data source into the output's property set.
