XML Reference: Siebel eBusiness Application Integration Volume V > Siebel XML Converters >
XML Hierarchy Converter Business Service
There are two methods for the XML Hierarchy Converter, as shown in Table 22. The arguments for each method appear in the tables that follow.
Table 22.  XML Hierarchy Converter Methods
Display Name
Name
Description
XML Document to XML Hierarchy
XMLDocToXMLHier
Converts an XML document into an XML Hierarchy.
XML Hierarchy to XML Document
XMLHierToXMLDoc
Converts an XML Hierarchy into an XML document.
