Table 28. Integration Object Hierarchy to XML Hierarchy Input Arguments
Namespace |
Namespace |
String |
If a namespace is defined here, it will override any namespace defined in the user properties of an integration object. |
Integration Object Hierarchy |
SiebelMessage |
Hierarchy |
The integration object hierarchy to be converted. |
Use Siebel Message Envelope |
UseSiebelMessageEnvelope |
String |
Default is True. If set to True then the Siebel Message Envelope is used in the XML Hierarchy, otherwise the Siebel Message Envelope is not included. |
n/a |
GenerateNamespaceDecl |
String |
Default is False. If set to True, the namespace declaration will be generated. You must manually create and name this input argument if it is required by your business needs. |
n/a |
GenerateSchemaTypes |
String |
Default is False. If set to True, then XSD schema types will be generated if set on the integration objects user properties. You must manually create and name this input argument if it is required by your business needs. |
