XML Reference: Siebel eBusiness Application Integration Volume V > Siebel XML Converters > XML Converter Business Service > Property Set To XML Method ArgumentsTable 33 and Table 34 describe the arguments for the Property Set To XML method of the XML Converter. |
| XML Reference: Siebel eBusiness Application Integration Volume V |
