XML Reference: Siebel eBusiness Application Integration Volume V > XML Representation of Integration Object Instances >
Elements Within a Siebel Integration Object Document
An integration object can be textually represented as an XML document. In order to exchange data using the Siebel integration object document, you must have an understanding of its XML structure, including elements and attributes. The document can may include up to five different types of elements:
- SiebelMessage Element
- Object List Element
- Integration Component Element
- Component Container Element
- Integration Field Element
