XML Reference: Siebel eBusiness Application Integration Volume V > Overview > Special Characters in XML Documents >
Special (Escape) Characters
The EAI XML Converter can handle special characters for inbound and outbound XML, as shown in Table 3. Non-Siebel XML should already handle special characters before integrating into the Siebel application. Special characters are indicated by enclosing the text for the character between an ampersand (&) and a semicolon (;). Also, if the XML is passed in a URL, then URL encoding of special characters is required as shown in Table 3.
Table 3. XML Escape Characters (Character Entities)
%26lt%3B |
%26gt%3B |
%26amp%3B |
%26quot%3B |
%26apos%3B |
Unicode Character (Decimal) |
%26%2309%3B |
Unicode Character (Hex) |
%26%23x00B0%3B |
Date |
Must follow the ISO 8601 format |
N/A |
