XML Reference: Siebel eBusiness Application Integration Volume V > XML Representation of Property Sets >
Mapping Between Property Sets and XML
An arbitrary property set hierarchy can be serialized to XML and an XML document can be converted to a property set hierarchy using the XML Converter business service. This service is used by the Business Service Simulator screen to save property set inputs and outputs to a file from eScript. Each part of a property set object has a corresponding XML construct. Table 4 shows the mappings between parts of a property set hierarchy and their XML representation.
Table 4. Property Set to XML Mappings
PropertySet |
Element |
PropertySet Type |
Element name (If Type is not specified, the element name is set to PropertySet) |
PropertySet Value |
Element Character Data |
Property name |
Attribute name |
Property value |
Attribute value |
Child Property Set |
Child element |
