XML Reference: Siebel eBusiness Application Integration Volume V > XML Integration Objects and the DTD Wizard > How the DTD Wizard Creates XML Integration Objects > ConnectorsConnectors specify the order of elements and CAUTION: The Siebel DTD wizard does not support "one or the other" ( | ) relationships expressed in DTDs. "One or the other" ( | ) will be treated the same as "followed by" ( , ). |
XML Reference: Siebel eBusiness Application Integration Volume V |
