XML Reference: Siebel eBusiness Application Integration Volume V > XML Integration Objects and the DTD Wizard > How the DTD Wizard Creates XML Integration Objects >
Names
Name is the name of the component or the field of the integration object. Because these names have to be unique within an integration object, the names may have suffixes attached to make them unique.
- Property External Name is the name of the attribute or the element in the external system, such as CustName.
- Property XML Tag is the name of the tag in the XML, such as <customer>.
